关于GRR的样品选择
样品选择时,如果被测的十个样品一致性比较好,那其PV值就比较小,%GRR自然就较大,如果选的样品的一致性差一点,%GRR就好很多,那我们做GRR分析时,如何选择样品?是不是要把规格范围外的产品都选上?
惠惠80 (威望:11) (辽宁 大连) 汽车制造相关 经理 - 外企QM经理及MBB,群主(61625923)为...
赞同来自: chengying229 rockylion LWJ110 Hsiaozzzzz youyouuuuu
以下来自于福特汽车对于MSA中GRR取样的要求,我们已经执行很多年了,非常不错的取样方法,供你参考
Parts for Attribute Gauge R&R Study
• 25% of the parts should be near the lower specification limit (on both sides of the specification).
• 25% of the parts should be near the upper specification limit (on both sides of the specification).
• 30% of the parts should represent the expected process variation.
• 10% of the parts should be outside the upper gauge specification limit and beyond the 25% of
the parts near the specification as described above.
• 10% of the parts should be outside the lower gauge specification limit and beyond the 25% of
当然,以上的要求不止限于10件三人三次,可以12件四人三次等,多种方案;
10件三人三次时,
3个样本靠近规格上限
3个样本靠近规格下限
3个样本靠近规格中心
1个样本超出规格上限或下限;
一般没有问题的话,GRR的研究%和公差%的结果都较好,NDC也大于5
如果不好的话,肯定是有问题要分析再改善的~
10 个回复,游客无法查看回复,更多功能请登录注册
