组装、冲压、喷漆等专业词汇
组装专业词汇
Assembly line组装线
Layout布置图
Conveyer流水线物料板
Rivet table拉钉机
Rivet gun拉钉枪
Screw driver起子
Electric screw driver电动起子
Pneumatic screw driver气动起子
worktable 工作桌
OOBA开箱检查
fit together组装在一起
fasten锁紧(螺丝)
fixture 夹具(治具)
pallet栈板
barcode条码
barcode scanner条码扫描器
fuse together熔合
fuse machine热熔机
repair修理
operator作业员
QC品管
supervisor 课长
ME制造工程师
MT制造生技
cosmetic inspect外观检查
inner parts inspect内部检查
thumb screw大头螺丝
lbs. inch镑、英寸
EMI gasket导电条
front plate前板
rear plate后板
chassis 基座
bezel panel面板
power button电源按键
reset button重置键
Hi-pot test of SPS高源高压测试
Voltage switch of SPS
电源电压接拉键
sheet metal parts 冲件
plastic parts塑胶件
SOP制造作业程序
material check list物料检查表
work cell工作间
trolley台车
carton纸箱
sub-line支线
left fork叉车
personnel resource department
人力资源部
production department生产部门
planning department企划部
QC Section品管科
stamping factory冲压厂
painting factory烤漆厂
molding factory成型厂
common equipment常用设备
uncoiler and straightener整平机
punching machine 冲床
robot机械手
hydraulic machine油压机
lathe车床
planer |'plein|刨床
miller铣床
grinder磨床
driller钻床
linear cutting线切割
electrical sparkle电火花
welder电焊机
staker=reviting machine铆合机
position职务
president董事长
general manager总经理
special assistant manager特助
factory director厂长
department director部长
deputy manager | =vice manager副理
section supervisor课长
deputy section supervisor =vice section superisor副课长
group leader/supervisor组长
line supervisor线长
assistant manager助理
to move, to carry, to handle搬运
be put in storage入库
pack packing包装
to apply oil擦油
to file burr 锉毛刺
final inspection终检
to connect material接料
to reverse material 翻料
wet station沾湿台
Tiana天那水
cleaning cloth抹布
to load material上料
to unload material卸料
to return material/stock to退料
scraped |'skræpid|报废
scrape ..v.刮;削
deficient purchase来料不良
manufacture procedure制程
deficient manufacturing procedure制程不良
oxidation |' ksi'dein|氧化
scratch刮伤
dents压痕
defective upsiding down抽芽不良
defective to staking铆合不良
embedded lump镶块
feeding is not in place送料不到位
stamping-missing漏冲
production capacity生产力
education and training教育与训练
proposal improvement提案改善
spare parts=buffer备件
forklift叉车
trailer=long vehicle拖板车
compound die合模
die locker锁模器
pressure plate=plate pinch压板
bolt螺栓
name of a department部门名称
administration/general affairs dept总务部
automatic screwdriver电动启子
thickness gauge厚薄规
gauge(or jig)治具
power wire电源线
buzzle蜂鸣器
defective product label不良标签
identifying sheet list标示单
screwdriver holder起子插座
pedal踩踏板
stopper阻挡器
flow board流水板
hydraulic handjack油压板车
forklift叉车
pallet栈板
glove(s)手套
glove(s) with exposed fingers割手套
thumb大拇指
forefinger食指
midfinger中指
ring finger无名指
little finger小指
band-aid创可贴
iudustrial alcohol工业酒精
alcohol container沾湿台
head of screwdriver起子头
sweeper扫把
mop拖把
vaccum cleaner吸尘器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
chain链条
jack升降机
production line流水线
chain链条槽
magnetizer加磁器
lamp holder灯架
to mop the floor拖地
to clean the floor扫地
to clean a table擦桌子
air pipe 气管
packaging tool打包机
packaging打包
missing part漏件
wrong part错件
excessive defects过多的缺陷
critical defect极严重缺陷
major defect主要缺陷
minor defect次要缺陷
not up to standard不合规格
dimension/size is a little bigger尺寸偏大(小)
cosmetic defect外观不良
slipped screwhead/slippery screw head螺丝滑头
slipped screwhead/shippery screw thread滑手
speckle斑点
mildewed=moldy=mouldy发霉
rust生锈
deformation变形
burr(金属)flash(塑件)毛边
poor staking铆合不良
excesssive gap间隙过大
grease/oil stains油污
inclusion杂质
painting peel off脏污
shrinking/shrinkage缩水
mixed color杂色
scratch划伤
poor processing 制程不良
poor incoming part事件不良
fold of pakaging belt打包带折皱
painting make-up补漆
discoloration羿色
water spots水渍
polishing/surface processing表面处理
exposed metal/bare metal金属裸露
lack of painting烤漆不到位
safety安全
quality品质
delivery deadline交货期
cost成本
engineering工程
die repair模修
enterprise plan = enterprise expansion projects企划
QC品管
die worker模工
production, to produce生产
equipment设备
to start a press开机
stop/switch off a press关机
classification整理
regulation整顿
cleanness清扫
conservation清洁
culture教养
qualified products, up-to-grade products良品
defective products, not up-to-grade products不良品
waste废料
board看板
feeder送料机
sliding rack滑料架
defective product box不良品箱
die change 换模
to fix a die装模
to take apart a die拆模
to repair a die修模
packing material包材
basket蝴蝶竺
plastic basket胶筐
isolating plate baffle plate; barricade隔板
carton box纸箱
to pull and stretch拉深
to put material in place, to cut material, to input落料
to impose lines压线
to compress, compressing压缩
character die字模
to feed, feeding送料
transportation运输
(be)qualfied, up to grade合格
not up to grade, not qualified不合格
material change, stock change材料变更
feature change 特性变更
evaluation评估
prepare for, make preparations for 准备
parameters参数
rotating speed, revolution转速
manufacture management制造管理
abnormal handling异常处理
production unit生产单位
lots of production生产批量
steel plate钢板
roll material卷料
operation procedure作业流程
to revise, modify修订
to switch over to, switch---to throw--over switching over切换
engineering, project difficulty
工程瓶颈
stage die工程模
automation自动化
to stake, staking, reviting铆合
add lubricating oil加润滑油
shut die架模
shut height of a die架模高度
analog-mode device类模器
die lifter举模器
argon welding氩焊
vocabulary for stamping
Assembly line组装线
Layout布置图
Conveyer流水线物料板
Rivet table拉钉机
Rivet gun拉钉枪
Screw driver起子
worktable 工作桌
OOBA开箱检查
fit together组装在一起
fasten锁紧(螺丝)
fixture 夹具(治具)
pallet栈板
barcode条码
fuse together熔合
fuse machine热熔机
repair修理
operator作业员
QC品管
supervisor 课长
ME制造工程师
MT制造生技
thumb screw大头螺丝
lbs. inch镑、英寸
EMI gasket导电条
front plate前板
rear plate后板
chassis 基座
bezel panel面板
power button电源按键
reset button重置键
电源电压接拉键
plastic parts塑胶件
SOP制造作业程序
work cell工作间
trolley台车
carton纸箱
sub-line支线
left fork叉车
人力资源部
QC Section品管科
stamping factory冲压厂
painting factory烤漆厂
molding factory成型厂
punching machine 冲床
robot机械手
lathe车床
planer |'plein|刨床
miller铣床
grinder磨床
driller钻床
linear cutting线切割
welder电焊机
position职务
president董事长
general manager总经理
factory director厂长
line supervisor线长
assistant manager助理
be put in storage入库
pack packing包装
to apply oil擦油
to file burr 锉毛刺
final inspection终检
wet station沾湿台
Tiana天那水
cleaning cloth抹布
to load material上料
scrape ..v.刮;削
scratch刮伤
dents压痕
embedded lump镶块
stamping-missing漏冲
forklift叉车
compound die合模
die locker锁模器
bolt螺栓
thickness gauge厚薄规
gauge(or jig)治具
power wire电源线
buzzle蜂鸣器
pedal踩踏板
stopper阻挡器
flow board流水板
forklift叉车
pallet栈板
glove(s)手套
thumb大拇指
forefinger食指
midfinger中指
ring finger无名指
little finger小指
band-aid创可贴
sweeper扫把
mop拖把
vaccum cleaner吸尘器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
chain链条
jack升降机
production line流水线
chain链条槽
magnetizer加磁器
lamp holder灯架
to mop the floor拖地
to clean a table擦桌子
air pipe 气管
packaging tool打包机
packaging打包
missing part漏件
wrong part错件
major defect主要缺陷
minor defect次要缺陷
cosmetic defect外观不良
speckle斑点
rust生锈
deformation变形
burr(金属)flash(塑件)毛边
poor staking铆合不良
excesssive gap间隙过大
grease/oil stains油污
inclusion杂质
painting peel off脏污
mixed color杂色
scratch划伤
painting make-up补漆
discoloration羿色
water spots水渍
safety安全
quality品质
cost成本
engineering工程
die repair模修
QC品管
die worker模工
equipment设备
to start a press开机
classification整理
regulation整顿
cleanness清扫
conservation清洁
culture教养
waste废料
board看板
feeder送料机
sliding rack滑料架
die change 换模
to fix a die装模
to repair a die修模
packing material包材
basket蝴蝶竺
plastic basket胶筐
carton box纸箱
to impose lines压线
character die字模
to feed, feeding送料
transportation运输
feature change 特性变更
evaluation评估
parameters参数
production unit生产单位
steel plate钢板
roll material卷料
to revise, modify修订
工程瓶颈
stage die工程模
automation自动化
shut die架模
die lifter举模器
argon welding氩焊
48 个回复
江南瑞雪 (威望:0) (上海 闸北区) 汽车制造相关 工程师
