關於SPC的專業詞彙
人械料法环4MIE
80:20原理80:20Principle
准确度Accuracy
成品改善Action on Output
制程中对策Action on the Process
人员变异Appraiser Variation
计数值Attribute Data
平均数Average
中位数平均Average of Median
全距平均Average of Range
标准差平均Average of Standard Deviation
平均数-全距管制图Average-Range Control Chart
二项分配Binomial Distribution
平均数-标准差制图Average-Standard Deviation Control Chart
中心线Center Line;CL
中央极限定理Central Limit Theorem
管制界限Control Limits
持续改善Continual Improvement
管制图Control Chart
分散Dispersion
管制计划Control Plan
计件Count by Pieces
计点Count by Points
关键制程特性Critical Process Characteristics
共同原因Common Cause
每百万缺点数管制图Defect Parts Per Million Control Chart
分配Distribution
关键产品特性Critical Product Parameter
仪器变异Equipment Variation
连续随机变数Continuous Random Variable
估计平均数Estimated Average
离散随机变数Discrete Random Variable
单位缺点数Defects Per Unit
单位缺点数管制图Defects Per Unit Contro Chart
指数分配Exponential Distribution
估计不良率Estimated Process Percent Defectives
次数分配Frequency Distribution
估计标准差Estimated Standard Deviation
漏斗实验Funnel Experiment
个别值-移动全距管制图Individual-Moving Range Control Chart
仪器设备Gauge
每百万缺点数Defects Part Per Million;dppm
仪器设备能力研究GRR Study
绩效报告Information about Performance
直方图Histogram
固有制程变异Inherent Process Variation
个别值Individual
短期制程能力研究Short Term Process Capability Study
中心位置Location
管制下限Lower Control Limit;LCL
管制上限Upper Control Limit;UCL
中位数Median
规格下限Lower Specification Limit;LSL
混批Mixed Lot
量测系统误差Measurement System Error
标称植Nominal
中位数-全距管制图Median-Range Control Chart
常态分配Normal Distribution
不良数管制图Number of Defectives Control Chart
缺点数Number of Defects
缺点数管制图Number of Defects Control Chart
不良数Number of Defectives
每百万不良数Parts Per Million;ppm
不在管制状态下Out of Control
制程能力图Process Capability Chart
过度调整Overadjustment
制程绩效指数Process Performance Index
柏拉图Pareto Diagram
不良率管制图Percent Defectives Control Chart
不良率Percent Defectives
制造流程图Process Capability Chart
卜氏分析Poission Distribution
长期制程能力研究Long Term Process Capability Study
群体Population
简单随机抽样Simple Random Sampling
精密度Precision
分段随机抽样Stage Random Sampling
制程系统Process
统计制程管制Ststistical Process Control;SPC
制程能力Process Capability
制程能力图Run Chart
样本Sample 全距Range
抽样Sampling
抽样分配Sampling Distribution
合理的分组Rational Subgrouping
偏态Skewness
再生性Reproducibility
再现性Repeatability
特殊原因Special Cause
稳定性Stabiity
规格界限Specification Limits
标准差Standard Devivation
分层分析Stratification
分层批Stratified Lot
分层随机抽样Stratified Random Sampling
组平均数Subgroup Average
组标准差Subgroup Standard Deviation
组全距Subgroup Range
规格上限Upper Specification Limit;USL
系统抽样Systematic Sampling
组间变异Variation between Groups
总平均数Total Average
组内变异Variation within Group
干预Tempering
计量值Variable Data
良率Yield
总制程变异Total Process Variation
组中位数Subgroup Median
中心值Target
总变异Tota Variation
均匀分配Uniform Distribution
管制状态下Under Control
推移图Trend Chart
变异Variation
良率管制图Yield Control Chart
准确度Accuracy
计数值Attribute Data
平均数Average
中心线Center Line;CL
管制界限Control Limits
管制图Control Chart
分散Dispersion
管制计划Control Plan
计件Count by Pieces
计点Count by Points
共同原因Common Cause
分配Distribution
仪器设备Gauge
仪器设备能力研究GRR Study
直方图Histogram
个别值Individual
中心位置Location
中位数Median
混批Mixed Lot
标称植Nominal
过度调整Overadjustment
柏拉图Pareto Diagram
群体Population
精密度Precision
制程系统Process
制程能力图Run Chart
样本Sample 全距Range
抽样Sampling
偏态Skewness
再生性Reproducibility
再现性Repeatability
特殊原因Special Cause
稳定性Stabiity
分层分析Stratification
分层批Stratified Lot
组全距Subgroup Range
总平均数Total Average
干预Tempering
计量值Variable Data
良率Yield
组中位数Subgroup Median
中心值Target
总变异Tota Variation
管制状态下Under Control
推移图Trend Chart
变异Variation
3 个回复
冬虫 (威望:0)
