供应商业绩符合正态分布吗??
各位大虾,
昨晚,我把公司今年对供应商业绩的评估(上半年,下半年各一次)分别做了Symmetry分析,发现结果都不线性的。所以,我的问题来了
1。供应商业绩(分数)是不是正态分布?
2。如果不是,请问该是什么分布?
3,如果是,请问什么原因导致我司的数据不是正态分布?
Thank you.
Symmetry plots can be used to assess whether sample data come from a symmetric distribution. Many statistical procedures assume that data come from a normal distribution. However, many procedures are robust to violations of normality, so having data from a symmetric distribution is often sufficient. Other procedures, such as nonparametric methods, assume symmetric distributions rather than normal distributions. Therefore, a symmetry plot is a useful tool in many circumstances.
中草药 (威望:2) (江苏 昆山) 其它行业 经理
对你说的不是很明白,你的样本是什么,是每一个供应商的业绩,还是一个供应商的每个时间段的业绩?
6 个回复,游客无法查看回复,更多功能请登录注册
