How to select a Good GB Project
Aligned with Strategic Plan
Pain Point for the Organization
Impact on Major deliverable
Manageable scope
In the control of the Belt to fix the issue (Don’t Boil the Ocean)
Can be completed in expected timeframe
Data exists on the metric/defect being studied (or can be easily collected)
Benefits are obvious/easily calculable/significant
Support resources are available to help the Belt
Solution is NOT already known
OK to have a guess what the answer is…..just use the DMAICS process and data to confirm it
Avoid “Boil the Ocean” projects
Avoid IT intensive projects
Avoid capital intensive projects
Avoid large multi-functional projects (play in your own sandbox)
Avoid projects where metrics don’t exist
suyuwang (威望:0) (江苏 苏州) 机械制造 员工
很有道理,但是如果判断这些条件,或者条件的重要度是那些,毕竟不是所有的条件都好满足的。
LZ能不能给一份更详细的解释
还有,上面提到了这点我不是很认同
如果这种项目答案很清楚的,可能只需要很简单的步骤就可能解决了,如果套用DMAIC的话是不是有点太教条了。
成了为了做项目而做项目了。
我觉得工具的本质还是为了解决问题,而不是把问题变得更复杂:D
2 个回复,游客无法查看回复,更多功能请登录注册
