Operator Did Not Follow the Procedure
When investigating a
當我們在調查問題的原因時
problem, never stop at
不要只停留在
“operator did not follow the procedure”
“作業員未按照作業程序作業”
_Dig deeper__…_
_應探究更深層次__…_
當我們在調查問題的原因時
不要只停留在
“作業員未按照作業程序作業”
_Dig deeper__…_
_應探究更深層次__…_
cxywsq (威望:10) (江苏 苏州) 机械制造 質量經理 - 零缺陷管理Zd-ism
Does a standard procedure exist? If no, Create a standard Procedure
Is the operator trained? If no,Train operator
Was the procedure followed correctly? if no,Create a system to assure conformity to procedures
Is the procedure effective? If no ,Modify procedure & check effectiveness
Do you have the right person for this job or task?
Right person @ Right location
