电镀 外观缺陷 中英文对照
Revise date : Apr. 28th, 2004
Plating Defects 金屬電鍍外觀缺點
1 Black Drop 黑點
2 Bridging And Shorts 橋接與短路
3 Bubbles 氣泡
4 Cold Soldering 冷焊
5 Component is not as Specified 錯件
6 Component-Lead Damage 零件引腳破損
7 Component not Mounted in Correct Holes 零件錯位
8 Components End Overhang 零件移位(軸面)
9 Components Side Overhang 零件移位(徑面)
10 Components Tilted 零件傾斜
11 Components Cracks, Chip-Out, Nick 零件破裂
12 Exposed basis metal 露底材
13 Cracked/ Fractured Solder Joint 銲裂
14 Deformity, deformation 變形
15 Dewetted Plated Through Holes 鍍通孔銲錫不良
16 Dewetting 吃錫不良
17 Dull Solder Surface 焊點灰暗
18 Excess Solder 焊多
19 Flux Residue 助銲劑殘留
20 Icicle, Solder Projection 錫尖,錫柱
21 Insufficient Solder 錫不足
22 Insulation Melted 絕緣皮燒焦
23 Lead Extrusion not Meet Acceptance Requirement 錫面腳長不當
24 Less, Broken or Illegible Marking 印字模糊,漏印,斷字
25 Loosing Screw 螺絲未鎖緊
26 Masking Failure 拒焊膜不良
27 Menisus in Solder 塗裝材吃錫
28 Missing/ Lacking Parts 缺件
29 Nodules 鍍瘤
30 Nonwetting 不吃錫,拒銲
31 Open 斷路
32 Over Plating 擴散
33 Oxidation 氧化
0 个回复,游客无法查看回复,更多功能请登录注册
275641119
走了很多不该走的路。。。
