破解EXCEL工作表保护(亲测可用)
EXCEL工作表保护密码破解
方法: 1\打开文件
2\工具---宏----录制新宏---输入名字如:aa
3\停止录制(这样得到一个空宏)
4\工具---宏----宏,选aa,点编辑按钮
5\删除窗口中的所有字符(只有几个),替换为下面的内容:(复制吧)
6\关闭编辑窗口 7\工具---宏-----宏,选AllInternalPasswords,运行,确定两次,等2分钟,再确定.OK,没有密码了!!
内容如下:
Public Sub AllInternalPasswords()
' Breaks worksheet and workbook structure passwords. Bob McCormick
' probably originator of base code algorithm modified for coverage
' of workbook structure / windows passwords and for multiple passwords
' Norman Harker and JE McGimpsey 27-Dec-2002 (Version 1.1)
' Modified 2003-Apr-04 by JEM: All msgs to constants, and
' eliminate one Exit Sub (Version 1.1.1)
' Reveals hashed passwords NOT original passwords
Const DBLSPACE As String = vbNewLine & vbNewLine
Const AUTHORS As String = DBLSPACE & vbNewLine & _
"Adapted from Bob McCormick base code by" & _
"Norman Harker and JE McGimpsey"
Const HEADER As String = "AllInternalPasswords User Message"
Const VERSION As String = DBLSPACE & "Version 1.1.1 2003-Apr-04"
Const REPBACK As String = DBLSPACE & "Please report failure " & _
"to the microsoft.public.excel.programming newsgroup."
Const ALLCLEAR As String = DBLSPACE & "The workbook should " & _
"now be free of all password protection, so make sure you:" & _
DBLSPACE & "SAVE IT NOW!" & DBLSPACE & "and also" & _
DBLSPACE & "BACKUP!, BACKUP!!, BACKUP!!!" & _
DBLSPACE & "Also, remember that the password was " & _
"put there for a reason. Don't stuff up crucial formulas " & _
"or data." & DBLSPACE & "Access and use of some data " & _
"may be an offense. If in doubt, don't."
Const MSGNOPWORDS1 As String = "There were no passwords on " & _
"sheets, or workbook structure or windows." & AUTHORS & VERSION
Const MSGNOPWORDS2 As String = "There was no protection to " & _
"workbook structure or windows." & DBLSPACE & _
"Proceeding to unprotect sheets." & AUTHORS & VERSION
Const MSGTAKETIME As String = "After pressing OK button this " & _
"will take some time." & DBLSPACE & "Amount of time " & _
"depends on how many different passwords, the " & _
"passwords, and your computer's specification." & DBLSPACE & _
"Just be patient! Make me a coffee!" & AUTHORS & VERSION
Const MSGPWORDFOUND1 As String = "You had a Worksheet " & _
"Structure or Windows Password set." & DBLSPACE & _
"The password found was: " & DBLSPACE & "$$" & DBLSPACE & _
"Note it down for potential future use in other workbooks by " & _
"the same person who set this password." & DBLSPACE & _
"Now to check and clear other passwords." & AUTHORS & VERSION
Const MSGPWORDFOUND2 As String = "You had a Worksheet " & _
"password set." & DBLSPACE & "The password found was: " & _
DBLSPACE & "$$" & DBLSPACE & "Note it down for potential " & _
"future use in other workbooks by same person who " & _
"set this password." & DBLSPACE & "Now to check and clear " & _
"other passwords." & AUTHORS & VERSION
Const MSGONLYONE As String = "Only structure / windows " & _
"protected with the password that was just found." & _
ALLCLEAR & AUTHORS & VERSION & REPBACK
Dim w1 As Worksheet, w2 As Worksheet
Dim i As Integer, j As Integer, k As Integer, l As Integer
Dim m As Integer, n As Integer, i1 As Integer, i2 As Integer
Dim i3 As Integer, i4 As Integer, i5 As Integer, i6 As Integer
Dim PWord1 As String
Dim ShTag As Boolean, WinTag As Boolean
Application.ScreenUpdating = False
With ActiveWorkbook
WinTag = .ProtectStructure Or .ProtectWindows
End With
ShTag = False
For Each w1 In Worksheets
ShTag = ShTag Or w1.ProtectContents
Next w1
If Not ShTag And Not WinTag Then
MsgBox MSGNOPWORDS1, vbInformation, HEADER
Exit Sub
End If
MsgBox MSGTAKETIME, vbInformation, HEADER
If Not WinTag Then
MsgBox MSGNOPWORDS2, vbInformation, HEADER
Else
On Error Resume Next
Do 'dummy do loop
For i = 65 To 66: For j = 65 To 66: For k = 65 To 66
For l = 65 To 66: For m = 65 To 66: For i1 = 65 To 66
For i2 = 65 To 66: For i3 = 65 To 66: For i4 = 65 To 66
For i5 = 65 To 66: For i6 = 65 To 66: For n = 32 To 126
With ActiveWorkbook
.Unprotect Chr(i) & Chr(j) & Chr(k) & _
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & _
Chr(i3) & Chr(i4) & Chr(i5) & Chr(i6) & Chr(n)
If .ProtectStructure = False And _
.ProtectWindows = False Then
PWord1 = Chr(i) & Chr(j) & Chr(k) & Chr(l) & _
Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
MsgBox Application.Substitute(MSGPWORDFOUND1, _
"$$", PWord1), vbInformation, HEADER
Exit Do 'Bypass all for...nexts
End If
End With
Next: Next: Next: Next: Next: Next
Loop Until True
On Error GoTo 0
End If
If WinTag And Not ShTag Then
MsgBox MSGONLYONE, vbInformation, HEADER
Exit Sub
End If
'Attempt clearance with PWord1
w1.Unprotect PWord1
Next w1
On Error GoTo 0
ShTag = False
'Checks for all clear ShTag triggered to 1 if not.
Next w1
If ShTag Then
With w1
If .ProtectContents Then
Do 'Dummy do loop
Chr(l) & Chr(m) & Chr(i1) & Chr(i2) & Chr(i3) & _
If Not .ProtectContents Then
MsgBox Application.Substitute(MSGPWORDFOUND2, _
'leverage finding Pword by trying on other sheets
For Each w2 In Worksheets
w2.Unprotect PWord1
Next w2
End If
Loop Until True
On Error GoTo 0
End If
End With
Next w1
End If
MsgBox ALLCLEAR & AUTHORS & VERSION & REPBACK, vbInformation, HEADER
End Sub
方法: 1\打开文件
3\停止录制(这样得到一个空宏)
内容如下:
With ActiveWorkbook
End With
ShTag = False
Next w1
Exit Sub
End If
If Not WinTag Then
Else
Do 'dummy do loop
With ActiveWorkbook
End If
End With
Loop Until True
On Error GoTo 0
End If
Exit Sub
End If
w1.Unprotect PWord1
Next w1
On Error GoTo 0
ShTag = False
Next w1
If ShTag Then
With w1
Do 'Dummy do loop
w2.Unprotect PWord1
Next w2
End If
Loop Until True
On Error GoTo 0
End If
End With
Next w1
End If
End Sub
冰客小白 (威望:0) (广西 柳州) 汽车制造相关 工程师 - 无
矛与盾同在:
如何设置保护单元格
一、设置ScrollArea属性
如果要使工作表的A1:E10单元格区域不被改动(下同),可以采取限定垂直滚动条范围的办法,隐藏A1:E10单元格区域,从而达到限定使用范围的目的。具体步骤如下:
1、执行“视图→工具栏→控件工具箱”命令,在打开的“控件工具箱”工具栏中,单击“属性”按钮,显示如图一所示的“属性”对话框。
2、在“属性”对话框的ScrollArea一栏里输入“A45:E45”(该范围可自己选定),然后按Enter键。
执行上述步骤后,我们发现A1:E10单元格区域不再出现在工作表中窗口中了,而且也无法移动垂直滚动条。由于ScrollArea属性不是永久的,关闭了文件,下次再打开时又可随意选择编辑上述区域。因此还需在ThisWorkbook代码模块中添加下面一段代码。
Private Sub Workbook_Open()
Worksheets("sheet1").ScrollArea = "A45:E45"
End Sub
这样,每次打开工作簿时,上述代码自动运行,并设定ScrollArea属性。作为保护工作表内容,这种方法是个不错的选择。
二、使用工作表保护
1、选择全部工作表,格式——单元格——保护——锁定,取消;
2、选中需要保护的单元格,格式——单元格——保护——锁定,选中;
3、工具——保护——保护工作表——,可以设置密码。
存在一个问题,如果按以上步骤锁定了工作表,其他未选中单元格可以修改但是单元格格式不能改变;如果允许修改单元格格式,可以在工具——保护——保护工作表——设置单元格格式,选中,但是问题也来了,你锁定的单元格虽然内容不能被修改但格式变成可修改的了。希望有高手帮忙完善这个问题,即未锁定单元格既能填写也能修改格式,而被锁定的单元格不能编辑也不能修改?
三、利用VBA设置访问权限
我们也可以利用VBA代码,设置权限密码,当编辑Sheet1工作表A1:E10单元格区域时,自动弹出输入密码提示框,密码正确时,该单元格被激活,否则,单元格内容不能被改动。具体方法如下:
执行“工具→宏→Visul Basic编辑器”命令或按下Alt+F11组合键,在代码窗口左侧的“工程资源管理器”窗口中,双击Excel对象下的Sheet1工作表,在右侧的代码窗口中输入以下代码:
Private Sub Worksheet_Change(ByVal Target As Range)
X = Target
End Sub
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
If Target.Column <= 5 And Target.Row <= 10 Then
Y = InputBox("请输入密码:")
If Y <> 123 Then
MsgBox "密码错误,你无编辑权限!"
Range("A11").Select
End If
End If
End Sub
