电泳手册
Automotive Electrocoat ReferenceManual 阴极电泳漆涂装手册
Table of Contents 目录
1.1. Historyof Electrocoat.............................................................................................. 1-1
电泳涂装的历史
1.2. WhyElectrocoat....................................................................................................... 1-1
为什么要采用电泳电泳涂装
1.2.1. Advantages................................................................................................. 1-1
优点
1.2.2. Limitations.................................................................................................. 1-3
局限性
1.3. Whatis Electrocoat.................................................................................................. 1-3
什么是电泳涂装
1.3.1. Anodic VersusCathodic............................................................................. 1-3
阳极电泳和阴极电泳的区别
1.4. ElectrochemicalReactions....................................................................................... 1-5
电化学反应
1.5. Componentsof Feed and Bath................................................................................. 1-8
槽液及加料组份
1.6. DeionizedWater....................................................................................................... 1-9
去离子水
1.7. Membranes............................................................................................................... 1-10
膜
1.7.1. UltrafilterMembranes............................................................................... 1-11
超滤膜
1.7.2. Anolyte Membranes.................................................................................. 1-12
阳极膜
1.8. SectionSummary...................................................................................................... 1-12
本节摘要
2.1. Introduction............................................................................................................... 2-1
介绍
2.2. GeneralDesign......................................................................................................... 2-1
总体设计
2.2.1. Basic Requirements................................................................................... 2-1
基本要求
2.2.2. Sanitary Pans.............................................................................................. 2-1
滴漏盘
2.2.3. Carrier Design............................................................................................ 2-2
吊具设计
2.3. MetalPreparation.................................................................................................... 2-2
金属前处理
2.3.1. Body Shop Washer..................................................................................... 2-2
车身清洗
2.3.2. Phosphating................................................................................................ 2-3
磷化
2.4. ElectrocoatTank...................................................................................................... 2-3
电泳槽
2.4.1. Direction of Flow........................................................................................ 2-3
流动方向
2.4.2. AdjustableWeir Plate............................................................................. 2-4
可调堰
2.4.3. Freeboardand Overflow............................................................................ 2-5
槽堰超出液面高度与溢流
2.4.4. Bottom Front EndFiltration....................................................................... 2-5
槽前段过滤
2.4.5. Dimensions:Clearance.............................................................................. 2-6
尺寸:间隙
2.4.6. Effective CoatingTime.............................................................................. 2-6
电泳时间
2.4.7. Angleof Entry............................................................................................ 2-6
入槽角度
2.5. Materialsof Construction........................................................................................ 2-7
建槽材料
2.5.1. Dip Tanks................................................................................................... 2-7
浸槽
2.5.2. Tank Enclosure.......................................................................................... 2-7
槽的间壁室
2.5.3. Tank Lining................................................................................................ 2-7
槽衬里
2.6. PaintCirculation....................................................................................................... 2-8
槽液循环
2.6.1. Surface Flow............................................................................................... 2-8
表面液流
2.6.2. Pipe Velocity............................................................................................... 2-8
管路内流速
2.6.3. Pumps.......................................................................................................... 2-8
泵
2.6.4 Piping.......................................................................................................... 2-9
管路
2.6.5. Valves......................................................................................................... 2-10
阀
2.6.6. Pressure Gauges........................................................................................ 2-11
压力表
2.6.7. Gasket Materials....................................................................................... 2-11
垫圈材料
2.6.8. Filtration..................................................................................................... 2-11
过滤
2.6.9. Paint Cooling.............................................................................................. 2-12
槽液冷却
2.7. Electrical................................................................................................................... 2-12
电气
2.7.1. Anodes........................................................................................................ 2-12
阳极
2.7.2. Roof Anodes............................................................................................... 2-13
阳极顶盖
2.7.3. Anolyte Cells.............................................................................................. 2-13
阳极隔膜系统
2.7.4. Power Supplies........................................................................................... 2-14
电源
2.7.5. Ultrafilters.................................................................................................. 2-15
超滤器
2.8. Rinses
淋洗
2.8.1. General Rinses........................................................................................... 2-15
概述
2.8.2. OverTank Rinses...................................................................................... 2-16
槽上冲洗
2.8.3. Recirculated Rinses#1 AND #2............................................................... 2-17
第一道和第二道冲洗
2.8.4. Drainage Between Rinses......................................................................... 2-18
各道冲洗之间的沥液
2.8.5. Dip Rinse.................................................................................................... 2-18
浸洗
2.8.6. Recirculated D IWater Rinse................................................................... 2-19
循环去离子水
2.9. DIor RO Water........................................................................................................ 2-19
去离子水或反渗透水
2.10. TemperatureProtection........................................................................................... 2-20
温度防护
2.11. LineStops................................................................................................................. 2-21
停线
2.12. Baking....................................................................................................................... 2-21
烘干
2.13. PaintStorage Tanks................................................................................................. 2-22
涂料储备槽
2.14. TankFeed................................................................................................................. 2-22
槽液配置
2.14.1. Resin Component....................................................................................... 2-22
树脂组分
2.14.2. Pigment Component................................................................................... 2-23
颜料浆组分
2.14.3. Acid Injection.............................................................................................. 2-23
加酸
3.1. Introduction............................................................................................................... 3-1
简介
3.2. MetalCleaning And Phosphating............................................................................ 3-1
金属清洗及磷化
3.2.1. Precleaning................................................................................................. 3-1
预清洗
3.2.2. Phosphating................................................................................................ 3-2
磷化
3.3. TankDesign and Construction................................................................................ 3-2
槽的设计和结构
3.4. PaintCirculation....................................................................................................... 3-3
槽液循环
3.5. TankElectrification.................................................................................................. 3-4
电泳槽加电装置
3.5.1. Anodes........................................................................................................ 3-4
阳极
3.5.2. Rectifiers.................................................................................................... 3-4
整流器
3.6. Ultrafiltration............................................................................................................ 3-5
超滤
3.7. RinseSystems.......................................................................................................... 3-6
清洗系统
3.8. Baking....................................................................................................................... 3-6
烘干
4.1. ElectrocoatSolids (Non-Volatile)............................................................................ 4-2
电泳漆固体分(不挥发份)
4.2. ElectrocoatpH.......................................................................................................... 4-3
电泳漆pH值
4.3. ElectrocoatConductivity.......................................................................................... 4-5
电泳漆的电导率
4.4. Panelsand Panel Ratings......................................................................................... 4-7
试板及试板评价
4.5. Measurementof Dry Film Thickness...................................................................... 4-12
干膜厚度测量
4.6. SandwichCompatibility Test.................................................................................... 4-7
相容性试验
Historyof Electrocoat 电泳涂装的历史在美国福特车厂George Brewer 博士的领导下,福特汽车公司从1957 年就着手研究电泳涂装。 这个计划是开发一种改善车身难涂部位防腐蚀性的方法。
汽车制造厂商们早已注意到汽车内部隐蔽处的锈蚀,但暴露在外的平面部位, 如车顶却不易锈蚀。虽然浸涂法能使涂料进入汽车内部,但是在烘干过程中,油漆因溶剂蒸发而被洗掉。于是Brewer博士领导小组努力去开发一种在施工过程中溶剂可以从涂膜中被排除掉的涂料,他们的工作开创了电泳涂装。
福特公司的第一个用于车轮涂装的生产槽在1961年7月4日开始运行,用来涂装汽车车身的Wixom 槽建于1963年, 这两个槽所用的均是阳极电泳漆。
开发电泳涂装后,虽然市场的需求稳定增长,但直到1973年阴极电泳漆问世时,市场需求才真正繁荣起来。1965年只有1%轿车用电泳底漆,到1970年增加到10%,现在几乎90%用电泳底漆。
WhyElectrocoat 为什么要电泳涂装由于电泳涂装具有明显的优点, 此工艺在过去的20年中已成为汽车涂底漆的最主要方法。以下的电泳涂装优点清楚地说明了它获得惊人成功的原因。
电泳漆在非常隐蔽的部位,如翻边以及箱式结构,仍能形成完整的保护膜,从而得到较高的防腐蚀性。
尤其与喷涂法相比,涂料利用率能达到95%以上,减少了涂料的浪费。
使用水做载体,免除了火灾危险。 大大降低了水和空气的污染,明显地减少了环保设备费用。
槽液粘度低(大约等于水的粘度),泵送容易,也利于被涂车身的沥干。
刚沉积电泳上的漆不溶于水, 允许彻底清洗,且可回收带出的槽液。
未固化的漆膜不粘手,甚至可以作某些处理。
不象喷涂的涂膜,电泳沉积的涂膜在烘干时不流掛。
与浸法涂装不同,电泳沉积在内腔部位的涂膜,在烘干过程中不会被热蒸汽洗掉。
由于生产过程自动化, 大大降低了直接劳动成本。
电泳工艺稳定,可保证漆膜均一涂于工件上。
电泳涂装法问世后,第一次考验是相当复杂的,但由于下列几个理由,实际上掌握它并不比其它涂装方法难。
槽的容量很大, 使涂料或工艺参数的波动减少到最小。
操作工艺参数已有明确的规定,且是以丰富的经验为基础。
PPG电泳漆实验室每周从槽中取的样品做实验,常常是在生产线上出现问题之前就能预报。
由于PPG电泳漆实验室时监控实验室,可以实现以下对工业规模的工艺过程的严密控制。
可以涂装各种各样的金属底材,且可进行不同条件的严格考验。
可以容易的对几个槽进行相互比较。
在电泳实验室使用的试验槽中,调近阳极-阴极间距可用来放大在这方面经常出现的问题。
虽然电泳的优点比缺点多,但是还是有一些局限性。电泳工艺只能用在导电的底材上;当涂装的物体烘干后。 不可能进行第二次电泳涂装。因此,电泳涂装主要被用来涂底漆;涂不同的颜色涂膜要在不同的槽中进行。
What is Electrocoat 什么是电泳涂装基于沉积的电泳方式,已经开发了阳极电泳漆和阴极电泳漆两种类型的电泳漆阳极电泳漆首先投入正式生产有两个原因:
早期的树脂制造技术都是以含酸基团的树脂为基础,中和后,他们可以溶于水。
当水溶性树脂沉积后,它可以恢复其酸性基团的功能。当此涂层被烘干时,这种酸性基团可使漆膜其迅速交联(固化)。
阴极电泳漆的树脂在1975年阳极型树脂商品化之前很长一段时间内就有能力制造了,但其正式投产之前要克服以下两个主要的问题。
降低碱性聚合物固化的温度,同时还要确保漆膜的均一性。
必须降低槽液的腐蚀性。
热固型树脂的固化过程称为交联, 这个过程是以热为动力,较小分子的沉积膜经化学交联形成一个完整的表面。.
电泳漆膜交联的反应取决于涂膜的化学反应环境,靠这些固化反应获得的涂膜结构,对其防腐性能]具有真正的实际价值。反应的条件也决定了烘干时间及温度,以及消耗能源。
阳极电泳槽液一般pH约为9,可沉积涂层却是高酸性。酸催化的交联反应比较容易进行。
对阴极电泳就有所不同了,阳离子树脂的交联反应可以在内部或外部进行,但因未固化阴离子涂膜具有碱性,所以外部交联反应较缓慢。
内部的交联是靠与阳离子树脂混合的氨基甲酸脂基团进行的。这些交联剂于正常槽液温度下在水中很稳定,但在固化温度下就变得活泼起来。通过采用一些特殊的处理工艺,确保这些交联剂不会在槽液温度起反应而引起槽液的不稳定性。
虽然多种树脂都可以适用于电泳涂装,但最常见的是热固型的
热固型的树脂在烘干时融合或融化成为一坚硬,均匀的耐溶剂涂膜。
研发人员必须确保树脂具有硬度,柔韧性,附着力,耐水及化学品性,颜料湿润性及其它特性。用于制造电泳漆的树脂还必须具备如下特性:
树脂必须可溶解或分散成一种稳定的溶液,可以适应多种生产条件。
树脂必须能沉积在一个电极上,形成一光滑,致密,绝缘,并含有颜料的湿涂膜。
必须能够泳涂外形复杂的工件。
必须在冲洗时不再被溶解掉。
经烘干后的涂膜具有机械及化学稳定性,以满足保护和(或)装饰的需要。
虽然电泳涂装的原理是从阳极电泳系统获得的, 但是直到开发出了阴极电泳涂装法以后, 电泳涂装才成为汽车涂底漆普遍采用的方法。阴极电泳漆有以下优点:
较低的膜厚具有良好的防腐蚀性。
保证工件内表面泳透力的同时,外表面上涂膜也不会过厚。
双金属复合层也能获得良好的防腐蚀性, 可适应日益扩大的镀锌钢板用量的需求。
它具有耐皂化性, 在全镀锌的车身板上可长期保持其附着力。
电泳本身耗电量少,从而用于冷却的冷量也少。
本身具有足够的光泽度,可喷涂或不喷涂中涂, 同时在没有中涂的情况下也不影响面漆的亮度。
其实, 阴极电泳的最主要优点还是防腐蚀性非常优良。材用阳极电泳时,由于通电时的阳极反应从被涂工件上溶下的金属离子常常包含在漆膜中,。在漆膜中存在的铁离子就成了开始生锈的诱因。另外,沉积时,阳粒子树脂呈碱性,这样就成为天然的缓蚀剂。
Electrochemical Reactions 电化学反应到此为止, 我们已经讨论了阳极漆和阴极漆,并且已使用了阳离子,阴离子等术语,虽然阳极和阴离子可以作为同义词使用, 其实他们是用于表示一个事物的两个不同方面的。
带正电荷的电极称为阳极,带负电荷的电极成为阴极,水溶液中含有的带电粒子称为离子,离子是带电荷的原子和分子,阴离子带负电荷,阳离子带正电荷,如果大家都明白异性相吸的道理,问题就简单了,阴极带负电:所以它排斥负电荷而吸引正电荷。
溶液中带正电荷的离子称为阳离子, 带负电荷的离子称为阴离子。这样,根据异性相吸的原理,阳离子(带正电荷)与阴极(带负电荷)相互吸引,由于阴极位置相对固定,故此阳离子便移向阴极,这种运动称为迁移。
带负电荷的离子把带正电的树脂分子存在于阴极系统的溶液中。树脂的溶解性取决于阴,阳离子的电平衡。
电泳漆沉积在阴极上时,此工艺称为阴极电泳,带正电荷的漆称为阳离子型电泳漆。故此“阴极的”极“阳离子的”两个术语即分别表示漆的沉积对象及沉积漆的带电类型。这两个术语常可互换使用。
电泳涂装工艺在英语中有以下几个名词:
Elpo
E-Coat
Electropainting
Electrodeposition
Electrophoretic Painting
跟电镀工艺相似,比如汽车保险杠度铬,电泳,电镀这两种工艺都是通过利用电流产生沉积。不同之处在于,电镀时沉积金属离子,电泳时沉积有机树脂分子。
阴极电泳涂装是一种将被涂件浸入水稀释的涂料中,进行类似电镀上漆的涂漆工艺,通过在涂料中通直流电, 在阴极电泳涂装体系中, 被涂件作为阴极(带负电)。油漆固体份带正电荷,因此被吸引到阴极。
漆膜的电沉积过程同时包含有电泳,电解,电沉积,电渗等过程。对于电泳槽的操作人员来说, 他们不一定要懂得这些原理,我们在此只是把在电泳槽中所发生的化学反应以及工艺原理进行解释。
电解是靠通电使导电液体分解。水电解生成氢气和氧气是大家最熟悉的电解例子。电解通常同时在一个或两个电极上析出气体。在电泳涂装过程中这种气体的析出却是不利的。它对后面将要讨论的重要特性“泳透力”有影响。由于气体析出与电流成正比,因此要避免在沉积过程中突然的电流波动,并且要将槽液电导率限制在特定的范围之内。这种电导的限制只是对油漆电导率的控制,并不考虑由于磷化液的带入或去离子水质量差所导致的杂离子污染杂质离子物所产生的电导率作用(诸如此类污染的作用将会在下文讨论)
电泳是在一电势电压作用下。导电介质中胶体离子的移动过程。例如,发生在电泳涂装过程中电泳的是颜料粒子及胶体树脂粒子的运动(移动),在这电势的作用下,这些粒子靠电泳过程移向阴极。
电沉积就是油漆粒子沉积在一个电极上。带正电的粒子将聚积在阴极上,带负电的粒子会在阳极上聚集。由于这些带负电的粒子(称离子)使带正电的树脂保持在溶液中,它们有时被叫做平衡离子。
涂料的漆基一般为阳离子型,沉积只发生在阴极上,它是一个不可逆过程。在阳极上不形成涂膜。
电沉积的第一步是水的电化学分解(电解)。如果漆液PH值呈中性, 在阴极上最初的反应是产生氢气和氢氧根离子(OH-),这个反应导致在阴极面上形成一高碱性边界层。当阳离子树脂(树脂及颜料)与氢氧根离子反应,变为不溶于水时,这就产生了沉积后的涂膜。但如果碱性边界层达不到大约12的临界PH值,将得不到不溶于水的涂膜。
电渗是要讨论的最后一个过程,当涂料固体份在阴极上沉积之后,此涂膜为半渗透性。水份从阴极附近通过沉积过程排斥出来,引起涂膜脱水,这种涂膜已具有抗物理变形性。
由于沉积涂膜的不溶于水性,允许用水清洗电泳板洗掉电泳带出的漆液。当被涂工件从电泳槽中出来时,在其表面上附着一层未沉积的槽液,为了获得外观良好的电泳漆膜,必须将带出的槽液洗掉。
总之, 当加电压于装有导电溶液槽中的两个电极时,就产生溶液的电解和带电粒子的电泳, 在阴极上发生聚积或沉积。这个过程一直持续到整个阴极表面被连续,均匀的涂膜所覆盖。
因为此电极沉积膜在既定的电压下具有一较高的电阻, 所以当所有表面及边缘被涂膜覆盖时,电泳沉积过程会自己停止。涂膜的厚度直接与沉积涂层的电阻成正比关系。
泳透力是一个比较性的参数。其定义是电泳涂料能使被涂装工件的凹深处或被隐密表面被涂上的程度。 电泳漆膜电阻高,则泳透力就好。
泳透力是电泳工艺最重要的参数之一,如果电泳涂装不能将防腐涂膜涂覆在用其它涂漆法所不可能达到的工件表面上,电泳涂装将永远仍是实验室研究的问题。由于泳透力如此重要,让我们探讨一下一些影响泳透力的重要因素。
Variable Relationship toThrowpower
变量 与泳透力的关系
**固体份在电沉积过程中被消耗,用作补充的组份称为补加漆料, 补加漆料包括高浓度的颜料浆和低粘度乳白色的树脂。PPG 公司向用户供应双组分补加漆料有以下两个原因:
颜料浆与树脂的加料比例可以根据用户的工艺操作所需及涂膜特性的特别要求而加以调整。
颜料浆通常比树脂的粘度高, 如果颜料浆预先与树脂混合,由于加树脂后会导致粘度降低而产生沉降, 会使操作者在使用过程中遇到困难。
用于电泳漆的颜料必须细心选择, 不能使用水溶性太强的或与水起反应的颜料。
典型的阴极电泳漆由以下四种成分组成:
可与酸形成水溶性的聚合物。
被一种专用的水溶性树脂湿润的颜料。
Coalescingsolvents.
混合溶剂。
Deionizedwater.
去离子水。
聚合物和颜料在前面已经讨论过,混合溶剂是水溶性的乙二醇醚类, 它有助树脂在水中的水分散和提高涂膜的均一性。
溶剂改善涂膜的均一性有两种途径:
当涂膜沉积时,发生某些聚结(树脂微粒聚到一起),这个作用有助于增强涂膜的电阻及形成均一的涂膜。
在烘干过程中, 混合溶剂有助于涂膜的流平。
DeionizedWater 去离子水去离子水是一种将自来水或生水经处理后制成适合配电泳漆槽液用的水。 去离子工艺在工业成本方面远比蒸馏水或反渗透水经济得多。
蒸馏是把水煮沸然后冷凝除去不溶性杂质;反渗透是使用膜分离工艺达到同样的目的。
去离子是使自来水通过离子交换柱除去可离子的矿物质。此工艺需同时使用一强酸性阳离子交换柱和一强碱性阴离子交换柱以除去水中所有离子。
在去离子的第一步,阳离子(例如钙,镁,钠)被HO)。进水的化学成分,温度,操作压力等因素是离子交换工艺中的重要参数。
多年前,关于电泳漆系统用水的纯度的标准已被定出,而这些标准是由油漆制造厂 和最终用户共同开发和订立的。
目前,对阳离子漆(阴极电泳漆)系统的水纯度标准是10微姆欧或100000欧姆,欧姆是一个电阻单位,姆欧是导电性的计量单位(姆欧是欧姆的简单倒拼)。如果水质的电导率大于25 微姆欧, 槽液可能被污染。 水质低于25 微姆欧就不会引起什么问题,但也不会提供系统的水平。
为了防止漆液被污染, 电泳槽中要用去离子水。无机杂质会引起两个问题:
在电泳过程中无机物的存在会影响涂膜的外观和抗腐蚀性。
游离的无机物 带电荷,它们泳动并消耗用于涂漆的电能。 因为纯水是良好的溶剂,所以被 用于电泳槽液的配制, 电泳涂膜的最终淋洗及磷化后除去前处理残留物
离子交换的能力会随连续运行而降低, 最后达到失效点。这时,可用强酸和强碱再生。 为此, 盐酸(HCL)和氢氧化钠(NaOH)溶液是推荐选用的材料, 决不能用片状NaOH, 因为它会引起阀门堵塞。交换柱再生之后,必须将所有的酸,碱(即使是微量)从系统中冲洗干净。 任何残留的酸碱,将对电泳槽液有破坏性影响。
Membranes 隔膜隔膜可以有选择性的允许一种粒子或一种分子通过,而挡住其它物质。使用特定尺寸的隔膜或使用在高电荷密度下运行的阳极液(电渗析)隔膜,可以达到这种状况。
在所有的电泳槽中泳用到两种隔膜, 阳极膜和超滤膜。阳极膜的作用是除去阳离子树脂电泳到工件时产生的酸积聚。超滤膜的作用有两个:
为闭路冲洗系统提供清洗液,冲洗掉由电泳槽中带出的浮漆,提高油漆利用率, 从而得到清洁的产品。
除去可能从磷化带入电泳槽中的水溶性污染物。
超滤膜是利用筛分原理工作藉此把所需的并能通过隔膜微孔的物质与不能通过的溶解分子颗粒分开。
一般的过滤是在压力作用下强行是液体通过多孔介质, 同样,在超滤中, 也实在压力下强行通过多孔介质。然而,这孔径要小1,000倍, 实际上, 隔膜的孔径小得连有些细菌都不能通过。
超滤膜可以通过水,酸,某些溶剂, 低分子量树脂及杂质离子。当电泳槽在正常的电导率参数内运行时,使用超滤供封闭循环的清洗系统,电导率高,表明有离子污染,当发生这样情况时,要排放超滤液,加去离子水供清洗用。
阻碍超滤液的生成有两种力,渗透力和浓差极化力。
渗透力是一个溶剂在其容积内浓度不断平衡的趋势。 这个力靠施加压力使油漆通过超滤装置来克服。
浓差极化力是分子在膜表面堆积或浓缩的趋势。仍然是要施加压力, 而且使油漆快速通过膜表面,来减少这个浓差极化力。超滤装置有四种类型中,后面两种最普及。
**这类隔膜以电渗析原理工作, 与超滤器不同,他们不需要压力。 由穿过隔膜的两侧提供所需的能量, 隔膜带有稠密的电荷密度及微孔。能有选择的允许带相应电荷的离子透过。
当树脂在阴极上沉淀时,平衡树脂的离子在溶液中累积,由于这些平衡离子是酸性的,它的累积使pH下降。然而,阳极液隔膜仅允许 酸通过, 但不允许 树脂通过。 这样,除去多余的酸,来维持槽液的正常pH值。
SectionSummary 本节摘要
要点:在阴极电泳系统中,树脂和颜料沉积在阴极上, 因此大大地提高了防腐蚀性,这个方法比阳极法优越。
下面列出了涂装一台车身时发生的四个反应。定义的关键字写在括号中。
Introduction 简介有关阴极电泳生产设备及控制的资料文章等很多。用户,设备供应厂家,油漆厂家及其它有关部门都有一些有价值的数据,设想及概念等。作为油漆供应商与电泳操作关系密切,我们整理出以下的一些关于在设计上需考虑的问题。这里的许多建议都来自我们现场服务及电泳涂装系统的故障排除过程所积累的经验。我们认为这些内容是必不可少的,并能令电泳漆在电泳系统中发挥最高的性能。
这并不意味着这些内容是必须全部执行才可达到的令人满意的操作的,但我们的观点是这是获得最高的涂层质量和最满意的系统操作所需要的。
General Design 总体设计不能有没有回路的管道。
电泳槽具有彻底的排空装置。为了完全排净,槽底应是倾斜的。管道也应是倾斜的来提获得一个低的排出点。
电泳槽里面没有裸露的金属
溢流应在冲洗中被利用来回收超滤液。
滴漏盘要连续走,随磷化和电泳生产线。电泳槽上方的防滴漏盘防止链油及灰尘 等不落在工件上。为使效果最佳,滴漏盘要尽可能宽, 要设计得不致使赃物回流到电泳槽中。在冲洗通廊间内的滴漏盘要保护整个运输链免受冲洗。
车身的吊具要设计成没有任何的吊具部件在车身上方。如果吊具部件在生产中处于工件的上方,很容易使磷化污染物和水滴到工具的顶上形成污染电泳槽的可能性。整体支撑工件的“C”型吊具在许多车厂内采用,过滤效果均好。这种设计对使用顶部阳极最好, 其结构能显著的节省油漆。 盒型或管型设计应为封闭式,以防止带出涂料,但允许在液面及喷洗面上方开泄压孔。设计还必须考虑工件沥液效果。(见图1)
Metal Preparation 金属前处理
有效的车身车间清洗设备应具有分散并除掉车身上矿物油,润滑剂及冲压拉延油。用高压水及皂液进行良好的预清洗能提高磷化作业效果。清洗也可减少带入电泳槽的或电泳涂膜烘干时发生缩孔的污染物。漆膜烘干时出现缩孔的问题在翻边及焊缝处最明显。
预清洗系统包括清除金属屑及焊渣, 它们是磷化和电泳槽内的污染物的来源。车底板亦是预清洗操作的重点部位之一。。
**磷化技术的开发是为阴极电泳涂装而服务的。磷化材料的特性取决于可否控制晶体的结构。成功的磷化操作完全取决于车身的清洁程度,磷化膜均匀与否以及最终残留的去离子水电导率是否低。
彻底的预清洗包括除去所有的油,冲压拉延剂,金属屑,其它碎屑颗粒及除掉所有的磷化残渣。磷化膜应完全均匀,无条痕,花纹或染色斑痕。晶粒应小而致密,膜重与磷化方式相称。水洗用循环去离子水的水质要保持在10us/cm**电泳槽要设计成使油漆沿单一循环路线连续运动,液面运动方向与运输链运行方面相同(见图2),实际经验证明,这样的设计能得到最干净的电泳车身。平稳的流向变化(在槽入口端)可考虑使用一“摇臂导向板”来实现。在工件入口端斜坡上喷头以引导漆液流向入口端,漆液虽改变流向,以有助于防止颜料沉淀。现在这种设计的两种形式已被普遍采用(见图3)。另外,底部中央有抽出过滤装置的双向流动系统也已被证明是成功的。
槽底的喷射嘴与竖立式带喷头侧管相结合可提供有效的槽液搅拌。必要时,为加强循环,可在出口端加引流管。引流管是大流量搅拌泵系统,它从液面使漆液运动,它使漆液做横跨底表面运动。用引流管时,大量漆液不经过滤而返回,因此当采用引流管时会产生染质污物和缩孔问题,就会延长问题存在的时间。槽底喷管要设在离槽底约3英寸(7-8cm)处,这样可使漆液沿槽底自由流动(见图2)。
在漆槽中搅拌不彻底的任何区域都会引起颜料沉淀。象排出口,储槽,泵井或空油漆管路等部位都会有颜料汇集。为防止此类沉淀,要在这些区域安设带喷射嘴的油漆返回管路。
槽底要有一定的坡度,这样主槽和溢流槽均可以完全排放,便于维修。也可以用电泳储存槽来盛装工艺槽偶然溢出的槽液。
Adjustable Weir Plate 可调堰
建议在电泳槽的出口端设可调的堰板以维持槽的液位并使槽液表面流动时会将泡沫和杂质污物从电泳槽带入溢流槽,漆液到溢流槽的落差应保持在6英寸(15cm)以内来防止起泡。建议在溢流槽底加喷嘴以保持搅拌。溢流槽的设计依使用的循环泵类型而定。(见图4)
Freeboard andOverflow 槽沿超出液面高度与溢流为防止漆液因偶然的加料失误而从槽中溢出,电泳槽应设计成其槽沿超出正常工作液面约9英吋(23cm)。这个安全系数足以满足在清洗槽清理时,将第一循环冲洗槽液泵入电泳槽的需要。在靠近槽顶处要装一个直径不小于3英寸的溢流管通向贮存槽,以便于材料回收。此管应设在主槽正常工作液位置上至少9英寸的位置,无疑建筑结构要能支撑注满时的总重量。要装高液位报警器及设备报警器,以保证系统安全进行,不发生事故。运输链的接油盘也必须在适当的高度上,以防止在高液位情况下被淹没。
实践证明,要从电泳槽中除去杂质需从槽底的进口倾斜面处抽出过滤漆液。这个概念称为槽底前端过滤,它对具有单一流向的槽最有效。槽前端过滤(作为新结构)有两种基本设计(见图5):
第一种是称为“底盒”的最简单设计,将进口端倾斜面底部(低于槽底)沿槽宽方向设计成12x12英吋(30 x 30 cm.)浅槽,起收集染质作用。在同一方向沿槽宽安装三个用泵控制的三个吸口,均匀析出槽液。
第二种设计为“沉积漏斗”,由一个附于槽底板进口倾斜底部的延伸状的盒体组成,漏斗状边壁端部是一个吸管口,盒体上部是一块覆盖槽宽的可调平板,用于调节漆液流入漏斗。此板宜倾斜布置,使之构成进口端倾斜底的最低部分。通常,在首次建槽加料时对此板进行调整。这种设计主要用于配有泵池的立式泵系统。事实上任何形式的泵系统均可用。
有50-60%的循环漆液需要通过槽底前端过滤系统。为防止大颗粒染质进入并堵塞泵体,应装有适当强度的不导电筛网(纤维增强塑料,玻璃纤维或涂漆不锈钢),筛网的开孔面积应尽可能大,以利于保证循环及防止染质堵塞。2英寸的网格较好。此种类型 只适用于卧式泵系统。
设计槽子时应确保车顶部至少在液面下12英寸(30cm),来提供及加强车辆上部漆液运动,减少水平沉淀,增加涂料在工件上成膜的均匀性(见图6)。此上部的间隙液将为增加顶部阳极提供空间。
电泳槽的大小应以能通过最大计划生产的车辆尺寸时仍使车体与阳极隔板表面保持12-15(30-37cm)英寸距离设计。车门开度应为6英寸(15cm),使漆液进出,增强对内表面的泳透力且使便于充分冲洗,槽子间隙要从“开门”处位置算起。工件与槽底之间的间隙应为18英寸(45cm)。
车身在阳极前方全浸时间最少为2分钟。为获得最好的泳透力,大部分的全浸没时间内应得到最高工作电压,这个条件在采用两段电压时更容易实现。
Angle of Entry 入槽角度30度入槽角适宜于浸没大多数车辆。然而,较陡的入槽角对赶出(移动)车顶底残留的空气有帮助,对无内衬要求的工件(如卡车驾驶室)特别建议采用较陡的入槽角,较陡的角度一般要求槽子较深,或改进运输链。当角小于30度时,要求槽子较长,且在赶出空气方面一般效果较差。
Materials of Construction 建槽材料浸槽应由3/8 英寸(9.5cm)厚的低碳钢板用双面焊接构成,所有焊缝要平滑无砂眼,槽子必须喷砂处理至露出底金属,在涂衬里之前应无锈。
槽的间壁室要从浸槽的入口一直到后冲洗室。因槽液上方会有少量有机酸蒸汽,冲洗室一般采用铝合金或不锈钢(304或603)制造,是因为电泳漆工作时会释出少量有机酸性气体。若不使用前述材料,则金属必须涂覆环氧涂层。在前处理和电泳系统中塑料板可用于间壁室敞开的区域。
槽衬里的目的是用高能量的绝缘体进行绝缘。对阴极电泳槽,泵池及所有的暴露金属表面建议涂一种加硅石的玻璃纤维加强的改性环氧树脂衬里,为了获得良好的附着力,必须对钢板表面喷砂处理,露出底金属,材料建议使用Ceilcote Company 生产的Corotine505 的产品。在衬里固化后,要在1.5-2 万电压下进行火花试验,确保完全的绝缘性。所有操作都必须依从于衬里制造厂商的说明书。
Paint Circulation 槽液循环槽液循环系统由三个重要的功能:
保持涂料均匀混合,防止颜料在槽中或在被涂物水平面上沉淀。
进行过滤以除去颗粒状脏物。
经过热交换器冷却槽液,以除去由涂装电功及泵运行的机械功所产生的热量。
系统要由4-6次/小时的通过过滤器的循环次数。因为防止颜料沉淀所进行的的维持槽液循环很重要,因此系统设计必须考虑一备用的可保证两台槽液循环泵运行的发电机,既保证在溢流槽的一台及前端系统的一台泵运行,还要能为去离子水泵供电,这些最低限度的预防措施能防止在长时间停电期间漆液变质或损坏过滤元件。
表面液流运动速度应为12-18英吋/秒(30-60英尺/分),且总是要比通过槽中的车身运动速度快。
管路内漆液流速应为8-12英尺。线速度取决于泵的种类,例如:12英尺/秒可能最好,节流阀和泵的气穴现象一样会使局部流速增加,导致阀附近的管路过早地磨损或腐蚀。
在电泳系统中,一般使用卧式及立式端吸式离心泵,泵的选用取决于经济条件,设计的限制或设计师的偏好。
垂直涡轮泵(相当于系统过程推动头)由于易于维修和较长的使用期限已被证明是节省成本的。
安装在溢流槽中的立式泵要求长轴,可防止在改变溢流液位时产生泡沫,长轴也要有较粗的轴径,以延长使用寿命,泵吸口要伸到距溢流槽底不少于1.5倍管径处,以尽量减小涡流及在清理溢流槽时能够较大限度的抽空溢流槽。所有泵都应有防止大的染质损坏叶轮及泵谷的保护措施。立式泵要配有安在泵头(吸口)的双层可拆卸不锈钢网(0.25英尺的直径),要将钢网涂以绝缘涂层以防止沉积上电泳漆(在电泳槽中泳好的钢丝网,烘干后即可),对保护网应每天要进行堵漏检查并每月清洗一次。
卧式泵必须配有可靠的阀将泵与系统分隔,泵还要装低位排净口及供冲洗用的去离子水接管口,我们发现备用泵是污染源,并且很难保持清洁,因此不推荐将备用泵安装在系统中。然而,应该是在维修过程中更换使用的备用泵,如果用管路将备用泵接入系统中,必须将其与漆液隔离,不使用时必须用去离子水冲洗,建议采用柔性泵连接件以减小管路张力及增加泵机械密封的寿命。
泵毂要用灰铸铁,不要使用球墨铸铁,叶轮及轴要用316不锈钢制成,以降低磨损(见图8典型的循环系统布置)。
2.6.4 Piping 管路连接到浸槽外部的管路要用规定要求的40无缝型“A”,管径不低于2.5 英寸的304不锈钢。典型的10种规格管径大于3英寸。直到目前普通钢管在系统中仍然存在并运行良好, 不锈钢将为未来的发展提供更好的适应性。槽内的分配头建议使用规范要求的80 的PVC管,以消除用钢管在接地条件下会沉积漆的情况。由于同样的原因,要使用加矿物填料的聚丙烯喷嘴。
焊接结构有一定的标准,对3英寸(7.6cm)或较大直径的管路效果良好,较细直径的管路,标准规定用有四氟乙烯带的螺纹管连接,如果是2英寸或较大内径的不锈钢管则要焊接。
所有管路都要倾斜布置,使之得以完全排净,而且排放口都要有阀门及螺纹盖或螺纹塞。
一般情况下不经常使用的管路,如溢流排放管及输送线,也要装有低位排出口及冲洗管线,在不使用时要将这些管中的漆排净。
在电泳系统中,偏心阀,球阀及蝶阀都有使用,其材料及结构对延长使用寿命很重要。
蝶阀的阀片及轴只能用316不锈钢制造。某些铸铁,特别是球铁寿命很短,阀座要用聚四氟乙烯制成。偏心阀的表面要涂以聚四氟乙烯,丙烯晴,丁二烯或合成橡胶-RS24以防止表面侵蚀。球阀要用316不锈钢制成以减少磨损。
Copper-, brass-, aluminum-, or zinc-coated components shouldnot be used in electrocoat systems. Rapid dissolution of these metals caused by铜,黄铜,铝或镀锌组件不能用于电泳系统,这些金属与阴极电泳漆接触很快溶解,将导致组件损坏并污染槽液。在管路中,阀门要尽可能靠近“T”型结构安装,以使阀面得到冲刷。(见图9)。在“死区”搅拌不到的漆会沉积,导致沉淀,引起杂质堆积和阀门堵塞,为
防止这种问题的发生,安装一高压冲洗系统可能是必须的。
Pressure Gauges
压力表
压力表安置在合适的位置对减少其堵塞是及重要的。只有将其安装在系统管线的上端,而且在系统管线路和压力表之间要安装一个阀门,不能水平或环型连管,不然会引起沉淀和堵塞,可用一种在连接管边缘装一个膜片的设计,由Ronningen-Peter 制造的Iso-Ring就是这样一种仪表,由乙二醇的化合物和水组成。压力表应按通常的操作压力在中央有一个大小范围。
最好的垫圈材料时异丁橡胶和聚四氟乙烯。其它材料如天然橡胶,乙烯再烯三元共聚物,合成橡胶及三元乙丙橡胶亦可。但氯丁橡胶和丁苯橡胶不能使用。
为了除去颗粒状染质,所有循环的漆液要100%的通过最大为25 微米的过滤袋或过滤棒。过滤材质必须用合成的不溶于水的材料制成,例如聚丙烯或丙烯酸烯纤维。不能使用单纤维过滤袋。
过滤器毂体应由不锈钢制成,或内表面要涂环氧树脂防止腐蚀。
用过滤稀油棉吸收剂在消除阴极电泳漆引起的缩孔方面的污染物已经获得成功,这种过滤器配合标准袋式过滤器使用是有效的,但要获得最佳效果,要求降低流速。
过滤器要适当布置,能使电泳漆转移到和从转储槽返回时能100%的过滤。
当今所有电泳漆组成的,操作温度都比最初的阴极电泳漆操作温度高,预计未来的发展趋势也是这样,故此需设有可降低厚膜电泳漆系统温度的冷却系统负载。
电泳漆冷却装置必须具有在满负荷生产情况下保持漆液在70°F(20°C)的能力,温度与给定温度的偏差不能大于1°F,一般的操作温度是85-95°F (29-35°C)。
对老的电泳漆系统来说,冷却装置必须在满负荷生产情况下保持其在60°F(15°C )的能力。温度与给定温度的偏差不能大于1°F。一般的操作温度是85-82°F
制冷剂及热交换器要以其在最高的预计电流强度下工作来设计。自来水的连接是为了制冷机在冷却过程中发生故障时使用。槽液的压力要保持超过冷却水的压力以防止槽液污染。在冷天时,可以用冷却塔,而不需要通过制冷机。
板柜式和榖管式热交换器都适用于阴极电泳系统,槽液在进入热交换器之前要经过滤,特别用板柜式热交换器时更为重要。这两种热交换器都要用不锈钢制造换热表面。
Electrical 电器 AnodeArea =(Vehicles/Minute x 2 Minutes x Surface Area/unit) / 4
建议阴极阳极比不能大于4:1,阳极表面是指当阳极是平板或半循环
型时通过工件与车身相连的被浸没的阳极部分。此比值用下列公式
计算。
阳极面积=(车身数/分x 2分x 表面积/车身)/4
全浸没时间长于2分钟时不要求加大阳极面积。阳极应沿各槽壁布置,深度不小于全浸段垂直槽壁深度的40%。在全浸3分钟的槽中,阳极的排布要从出口端开始向前排,在接地电源的进入系统,阳极一般不放在与车体进口邻近的地方。到阳极前的典型距离是1/2-1 个车厂。
两个电极端之间至少有一个极罩的间隙,以防止漆在电压较低区和极罩上沉积,如果两个极段之间电压超过75 伏,要留出两个极罩的间隙。电压超过100伏,要留出三个极罩的间隙,如果用二极管防止回流,一个极罩的间隙就足够了。
阳极要用316L不锈钢,厚度最好不小于1/8英吋(3.2cm),正常情况下,阳极缓慢溶解,其寿命取决于通过电泳槽的生产率。阳极的概率寿命可以达若干年,经试验涂覆有氧化钌成分的阳极使用寿命是不锈钢阳极的数倍,但初期投资也比不锈钢要多。系统设计时要为每个极罩配一个安培计,以便可连续观察各极罩的运行情况。极罩状况及操作数据将随时可以得到。这种设计可做得很好,在各个极罩上连接的分流器或直流变压器可很好的监视每个极罩。
板状及管状阳极一般封闭在可冲洗的阳极罩中,极罩由不导电材料制成,敞开面装有离子选择性隔膜(见图11)。
阳极液系统管路必须用不锈钢或塑料制成,要能耐pH 2.0-5.2 有机酸溶液,每快板状阳极必须以1加仑/10平方尺的有效阳极面积的速率洗涤,要装便宜的流量剂以监视流量,如果极液返回管为塑料,则在每个极罩上装一个不锈钢连接器以将极液接地(防止接触阳极时有电击)。阳极系统要能控制阳极液电导率在设定点的±100us/cm内。控制器及仪器量程应为0-10,000us/cm(见图12)。阳极液槽及电泳槽用“无极型”电导率传感器(如:Eoxboro 871 EC body code EV)时工作性能好。在新槽投料之前,所有极罩都要做渗漏试验,在投槽时,极罩中必须有去离子水,以防隔膜破裂。极罩渗漏或损坏时应立即更换。
当阳极液PH值接近3,对第四代产品电导率为400-1000 us/cm,第五代产品电导率为3000-6000 us/cm时,要充分排放阳极液,这时要考虑到废水的排放对系统的影响。第五代产品每1000英尺正常情况下应排放阳极液约10加仑。
整流器电压能使电压在0-500V之间可调,实践经验表明厚膜电泳漆电流消耗大约为2.5安培 .小时/100平方英尺,系统设计要考虑50%的电流余量以供将来发展,可用以下公式计算泳涂一台车所需总电流。
Amps Required=(2.5 Amp Hrs/100 Ft ) x(Coatable Surface/Minute) x (60 Minutes/Hr)
所需安培数=(2.5安培.小时/100平方英尺)x(能涂的面积/分)
x(60分/小时)
考虑安全系数,这个安培数乘以1.5来求出放大的规格,把总流量分成两份,每一部分单独配整流器(见图12),设计要考虑配有专用及独立启动的备用整流器,以确保即使整流器发生故障时生产也能继续进行且质量不降低。建议采用限流整流器以保护设备。考虑停链之后工艺槽中有工件在重新启动,要求有可调时间的渐升电压电路,这样的电路可防止电流脉冲损坏涂层继电器设备,从零伏升到工作电压的升压时间以10-15秒较好,要装有能控制不生产时(如午餐等)不为系统供电的控制器。
整流器“供电平稳”度或输出脉动率很重要,直流电要经滤波,电压脉冲幅度不超过平均直流电压的5%,满负荷情况下,电压脉动率要小于5%。
Ripple is defined as:
脉动率定义为:
100x RMS Voltage of the A.C. Wave on the D.C. / the Average D.C.
100 x在直流电压上的有效交流电压/平均直流电压
工件带接地电压入槽提供了最大的人身安全性,使开关系统更简化,且能得到对车身下部最长的电泳时间,同时也能减少电弧放电和烧坏电制,滑架等事故。
超滤器系统的设计要从超滤膜供应厂获得,系统要设计成能为100平方英尺/分的涂装面积提供3.0加仑/分的超滤液,超滤有两个目的:为有效闭路冲洗系统供应充足的超滤液和净化漆中水溶性杂质。
排放的超滤液要与其它电泳废水一样处理,净化排放的超滤液损失量要用新鲜的去离子水补充。
如果用低碳钢制造超滤液储用槽要涂环氧材料以防止气相符时,亦可用不锈钢或玻璃钢制成。无论如何,超滤液储槽都应设计能靠重力溢流至所有超滤液循环冲洗槽和电泳槽。
超滤液一般是沿冲洗途径返回到电泳槽中。然而,也要设计能使渗透液从超滤器直接返回到点泳槽的管路,如果槽液在转移槽,超滤装置仍运行,这管路必须能使超率液直接返回到转移槽中。
超滤装置会因颜料堵塞超滤膜以至渗透液生产量下降,此时如果通过适当清洗,流量可得到恢复。但超滤装置的规格必须大一些,即使在低的渗透量时也可为每100平方英尺/分得涂装面积供应3.0加仑/分的超滤液。
超滤装置流量下降到设计流量的70%之前,就应进行清洗。
Rinses 冲洗电泳后冲洗可除去电泳漆膜表面附着的一薄层浮漆。电泳表面带有少量浮漆会引起漆膜缺陷,在车身露出电泳槽后要尽快冲洗,不能长于1分钟。
高效率的“闭路”,“重力回流”冲洗系统是必要的(见图16),这些系统是在最后一道工序用新鲜超滤液,随工序向前溢流返回电泳槽,以回收漆液固体份,此系统以五道超滤液冲洗加二道去离子水冲洗较好,编排如下:
OverTank Rinse: Single orDouble Header
槽上冲洗 单排或双排喷管
RecirculatedRinse 1: 30-45 Seconds
第一道循环超滤液冲洗: 30-45 秒
DipRinse: Complete Immersion
超滤液浸洗: 全浸没
RecirculatedRinse 2: 30-45 Seconds
第二道循环超滤液冲洗 30-45秒
FreshUltrafiltrate: Singleor Double Header
新鲜超滤液冲洗 单排或双排喷管
DrainArea: Minimumof 60 Seconds
沥液区 最少60秒
RecirculatedDI Rinse: 30-45 SecondsFresh
循环去离子说: 30-45秒
VirginDI Rinse: Singleor Double Header
新鲜去离子水 单排或双排去离子水
DrainTime Between Rinses: 1 Minute
两道去离子水冲洗沥液时间:1分钟
所有的冲洗及泵池都要有良好的排液及搅拌装置,以保证清洗有效及迅速。超滤液冲洗方面可选用的结构材料包括涂有涂层的钢管及无镀层管。冲洗壁板,顶板及清洁屏蔽用不锈钢或涂有涂层的钢管及无镀层管。如使用无铅电泳漆,则只可用不锈钢PVC制造。
Over Tank Rinses 槽上冲洗r槽上冲洗使用第一循环超滤液在车身一出槽就马上冲洗,其位置在靠近或正好在溢流槽后面布置,以收集由喷洗造成的泡沫,疏松附着车身的浮漆,并且要在车身离开电泳槽不超过三十秒内完成冲洗。通过清洗也可保持工件湿润,从而使工件不会玷污或干结,来保证在以后的冲洗更加清洁。
此溢流量要设计成少于超滤装置输出量2-3加仑/分。剩余的超滤液靠重力从第一次循环冲洗溢流回到电泳槽。冲洗喷头要安装适当,使喷射面覆盖整个车身。喷射幅面为85**第一道和第二道循环冲洗可设计成相同规格,每分钟50GPM(加仑/分)/100平方英尺(9.3 M2)的冲洗量已相当充分。喷嘴要调整到能喷到车身内部和外部的所有表面。外表面很容易清理,直接喷洗那些朝下的表面(见图14),这些冲洗要分四个区段并带专用控制阀。
对外表面的冲洗建议使用有利于控制泡沫的Spraying Systems 生产的V型喷嘴。平嘴型喷嘴(VeeJet)也可以使用但容易使超滤液形成水物而引起泡沫。喷嘴集中在18英寸时(45cm)平管上冲洗效果好,且可避免喷射图形相互干扰而导致严重起泡,建议设底板喷管以喷洗车身底板,底部喷管必须配单独的控制阀以泳喷到接灰盘。内表面喷嘴视各种要求而定,需要30-40%的零度喷嘴或扁管喷嘴作为车身横截面喷洗及车顶裙冲洗用。输送管道应为不锈钢或不锈钢和PVC的化合物。
系统要设计成使产生的泡沫减至最少,这样车身靠近底部并在喷管下面提供一个“小池”这些“池”构成了整个冲洗槽,在使用立式泵时也成为泵井,池外堰不能超过冲洗段的沥水堰。槽子的容积应为泵流量的3-4倍,系统设计包括提供槽底的搅拌,要求搅拌即使在不生产期间也要连续进行。
一般使用长轴或立式泵,使用是用于循环冲洗可以消除使用卧式泵需要的密封问题,使用立式泵时要考虑一个一直伸到泵池的部12英寸(30cm )之内的泡沫隔板(见图14),以尽量减少冲洗室外的泡沫形成,冲洗的压力应为5-10 psi(磅/平方英寸)。
冲洗槽用涂上Flakeline600L的钢或等同的304 或305不锈钢制成。冲洗液要经装在泵和喷管之间的25um(最大)的过滤器过滤。考重力从超滤液储槽自流到冲洗工序,在将含漆浓度高的超滤液返回到电泳槽是最简单的,也是最安全的冲洗溢流方式。在不生产期间仍要维持逆流以减少冲洗液中的涂料固体份。
在第二次循环冲洗之后,可紧接着配置新鲜超滤液冲洗,在新鲜超滤液冲洗之前,要沥水10-20秒。
Drain time between all rinses should bea minimum of one minute (except for the fresh UF and the fresh DI rinses). Adrain time of no less than one minute from the virgin UF rinse and the high point in the drainpan of the recirculated DI rinse is mandatory to prevent excessive UFcarry-out. The drains for hand rinse and/or green sanding should go directly toindustrial waste with the recirculated DI rinse overflow.
所有的冲洗之间沥液时间最少应为1分钟(新鲜超滤液和新鲜去离子水冲洗除外),新鲜超滤液洗与循环去离子水洗之间的沥液时间不能少于1分钟,以防止超滤液过多带出。手工冲洗或湿打磨(green standing) 的排口与循环去离子水冲洗的溢流之节排至工业废水系统。也推荐采用运输链“驼峰”以减少“漆液带出”。
浸洗要使车身能在尽可能
- Introduction to Electrocoat.............................................. 1-1
电泳涂装的历史
为什么要采用电泳电泳涂装
优点
局限性
什么是电泳涂装
阳极电泳和阴极电泳的区别
电化学反应
槽液及加料组份
去离子水
膜
超滤膜
阳极膜
本节摘要
- DesignConsiderations............................................................... 2-1
介绍
总体设计
基本要求
滴漏盘
吊具设计
金属前处理
车身清洗
磷化
电泳槽
流动方向
可调堰
槽堰超出液面高度与溢流
槽前段过滤
尺寸:间隙
电泳时间
入槽角度
建槽材料
浸槽
槽的间壁室
槽衬里
槽液循环
表面液流
管路内流速
泵
管路
阀
压力表
垫圈材料
过滤
槽液冷却
电气
阳极
阳极顶盖
阳极隔膜系统
电源
超滤器
2.8. Rinses
淋洗
概述
槽上冲洗
第一道和第二道冲洗
各道冲洗之间的沥液
浸洗
循环去离子水
去离子水或反渗透水
温度防护
停线
烘干
涂料储备槽
槽液配置
树脂组分
颜料浆组分
加酸
- SystemOperation.......................................................................... 3-1
简介
金属清洗及磷化
预清洗
磷化
槽的设计和结构
槽液循环
电泳槽加电装置
阳极
整流器
超滤
清洗系统
烘干
- AnalyticalTests............................................................................ 4-1
电泳漆固体分(不挥发份)
电泳漆pH值
电泳漆的电导率
试板及试板评价
干膜厚度测量
相容性试验
- TERMINOLOGY.................................................................................... 5-1
可以容易的对几个槽进行相互比较。
必须降低槽液的腐蚀性。
必须能够泳涂外形复杂的工件。
必须在冲洗时不再被溶解掉。
较低的膜厚具有良好的防腐蚀性。
电泳涂装工艺在英语中有以下几个名词:
Elpo
E-Coat
Electropainting
Electrodeposition
变量 与泳透力的关系
典型的阴极电泳漆由以下四种成分组成:
可与酸形成水溶性的聚合物。
被一种专用的水溶性树脂湿润的颜料。
Coalescingsolvents.
混合溶剂。
Deionizedwater.
去离子水。
溶剂改善涂膜的均一性有两种途径:
SectionSummary 本节摘要
电泳槽里面没有裸露的金属
溢流应在冲洗中被利用来回收超滤液。
进行过滤以除去颗粒状脏物。
Pressure Gauges
压力表
计算。
x(60分/小时)
脉动率定义为:
槽上冲洗 单排或双排喷管
第一道循环超滤液冲洗: 30-45 秒
超滤液浸洗: 全浸没
第二道循环超滤液冲洗 30-45秒
新鲜超滤液冲洗 单排或双排喷管
沥液区 最少60秒
循环去离子说: 30-45秒
新鲜去离子水 单排或双排去离子水
两道去离子水冲洗沥液时间:1分钟
浸洗要使车身能在尽可能
EZY2005 (威望:11) (广东 东莞) 电子制造 员工 - 专业管理,专职体系,专心品质!推行TS16949...
