Philips Healthcare, which I ever served, the SQM is in quite high grade with remarkable salary (corporate grade 60 to 70). I thought the SQM in Shenzhen is also the same, even you may work for CLS or Lighting. Congratulation!
In general, the position is good but with some pressure from internal and external. Just take care.
10 个回复
chyt1982 (威望:1) (江苏 ) 生物医药 工程师
