船舶英语手册
机舱部分 ENGINE ROOM PART
一、机舱设备 Machines and equipment in engine room
1、主机 Main engine
1)主机油底壳 The sump tank of M.E.
2)主机飞轮 Fly wheel of M.E
3)活塞 Piston
2、发电机 Generator engine
1)应急发电机 Emergency generator engine
2)辅机 Auxiliary
3、锅炉 Boiler
1)组合锅炉 The composite boiler
2)锅炉安全阀 The safety valve of boiler
32
3)燃烧器 Oil burner unit
4)水位表 Water level gauge
5)水位控制器 Water level controller
6)过量蒸气调节阀 Excess steam pressure control valve
4、舵机
1)舵机间 Steering room
2)舵机装置 Steering-gear
3)手操舵装置 Trick wheel plant
4)油缸 Oil cylinder
5)反馈装置 Feedback device
6)舵 Rudder
舵叶 Rudder blade
舵杆 Rudder stock
上舵承 Rudder carrier
33
舵销 Rudder pintle
舵杆衬套 rudder stock liner
舵杆轴套 Sleeve for rudder stock
舵销承衬套 Bush for rudder pintle
舵销轴套 Sleeve for rudder pintle
上舵承底座 Rudder carrier seat
舵销承座 Pintle bearing
舵杆承座 Rudder stock bearing
挡圈 Retaining ring
舵柄 Tiller
7)舵角 The angle of rudder
5、空压机 Air compressor
1)主空压机 Emergency air compressor
2)应急空压机
34
3)主空气瓶 Main air reservoir
4)应急空气瓶 Emergency air reservoir
5、控制空气瓶 Control air reservoir
6、空气干燥器 Air dryer
7、分油机 Oil purifier
1)燃油分油机 Fuel oil purifier
2)柴油分油机 Diesel oil purifier
3)滑油分油机 Lubricate oil purifier
4)排渣 Sludge discharge
8、制淡装置 Fresh water generator
9、焚烧炉 Incinerator
10、油水分离器 Oil water separator
11、生活污水处理器 Sewage treat plant
12、大气冷凝器 Atmosphere condenser
35
热水井 Cascade and inspection(hot well)
滑油自清滤器 The automatic back-flash lubricating oil filter
燃油单元 Fuel oil unit
1)主机燃油单元 Fuel oil unit of M.E
2)付机燃油单元 Fuel oil unit of A.E
3)粘度计 Viscosity controller
泵 Pump
1)主机滑油泵 Main engine lubricating oil pump
2)主机缸套水泵 Main engine cylinder cooling water
pump
3)主机缸套水预热泵 Main engine cylinder cooling water preheating pump
4)主机海水泵 Main engine sea water pump
36
5)主机燃油供给泵 Main engine fuel oil supply pump
6)主机燃油增压泵 Main engine fuel oil booster pump
7)主机十字头泵 Main engine cross head pump
8)付机海水泵 Generator engine sea water pump
9)付机缸套水泵 Generator engine cylinder cooling water pump
10)锅炉给水泵 Feed water pump of boiler
11)锅炉燃油泵 Fuel oil pump of boiler
12)分油机供给泵 Fuel oil supply pump of purifier
13)制淡海水泵 Sea water pump of fresh water generator
14)压载泵 Ballast pump
15)舱底消防泵 Bilge and fire pump
37
17)油渣泵 Sludge oil pump
18)柴油输送泵 Diesel oil transport pump
19)燃油油输送泵 Fuel oil transport pump
20)汽缸油输送泵 Cylinder oil transport pump
21)淡水输送泵 Fresh water transport pump
22)热水循环泵 Hot water circulating pump
23)饮水日用泵 Drinking water pump
舱底消防总用泵 Bilge, fire and G.S pump
喷淋泵 Sprinkling pump
停泊海水泵 Harbor sea water pump
二、各种舱(箱)柜 All kinds of tank
1、柴油日用柜 Diesel oil daily tank
38
2、柴油澄清舱 Diesel oil setting tank
3、燃油日用柜 Fuel oil daily tank
4、燃油澄清舱 Fuel oil setting tank
5、滑油澄清舱 Lubricating oil setting tank
6、滑油储藏舱 Lubricating oil store tank
7、滑油循环舱 Lubricating oil circulating tank
8、燃油溢油舱 Fuel oil overflow tank
9、燃油油渣舱 Fuel oil sludge tank
10燃油深舱 Fuel oil deep tank
11滑油污油舱 Lubricating dirty oil tank
12滑油溢油舱 Lubricating oil overflow tank
13滑油油渣打舱 Lubricating oil sludge tank
14主机淡水膨胀水箱 M.E fresh water expansion tank
15付机淡水膨胀水箱 A.E fresh water expansion tank
39
16、淡水压力柜 Fresh water pressure tank
17、热水压力柜 Hot water pressure tank
18、饮水压力柜 Drinking water pressure tank
19、淡水舱 Fresh water tank
20、饮水舱 Drinking water tank
21、锅炉水舱 Boiler water tank
22、分油机工作水箱 Purify operating water tank
23、汽缸油日用柜 Cylinder oil daily tank
24、尾管滑油重力柜 Gravity tank of tube oil
25、排气水封箱 Exhaust seal water tank
26、蒸馏水水舱 Distilling water tank
27、污水井 Bilge well
40
1、滑油系统 Lubricating oil piping system
2、燃油系统 Fuel oil piping system
3、海水系统 Sea water piping system
4、缸套水系统 Cylinder cooling water piping system
5、启动空气系统 Start air piping system
6、控制空气系统 Control air piping system
7、排气系统 Exhaust piping system
8、日用供水系统 Daily water piping system
9、蒸汽系统 Steam piping system
10 、锅炉给水和凝水系统 Feed water and condensate of boiler piping system
11、燃油净油系统 Fuel oil purified piping system
12、燃油输送系统 Fuel oil transport piping system
1、主机 Main engine
3)活塞 Piston
2)辅机 Auxiliary
3、锅炉 Boiler
32
4、舵机
1)舵机间 Steering room
4)油缸 Oil cylinder
6)舵 Rudder
舵叶 Rudder blade
舵杆 Rudder stock
上舵承 Rudder carrier
33
舵销 Rudder pintle
舵销承座 Pintle bearing
挡圈 Retaining ring
舵柄 Tiller
2)应急空压机
34
6、空气干燥器 Air dryer
7、分油机 Oil purifier
9、焚烧炉 Incinerator
35
燃油单元 Fuel oil unit
泵 Pump
pump
36
14)压载泵 Ballast pump
37
喷淋泵 Sprinkling pump
38
39
27、污水井 Bilge well
40
0 个回复
