IP标准说明
IP stands for 'Ingress Protection'
An IP number is used to specify the environmental protection of enclosures
around electronic equipment. These ratings are determined by specific
tests.
The IP number is composed of two numbers, the first referring to the
protection against solid objects and the second against liquids. The
higher the number, the better the protection.
Note: All Aceeca devices are manufactured and tested to IP67 standards.
First Number
0- No protection (Sometimes X)
1- Protected against solid objects up to 50mm?
2- Protected against solid objects up to 12mm?
3- Protected against solid objects up to 2.5mm?
4- Protected against solid objects up to 1mm?
5- Protected against dust, limited ingress (no harmful deposit)
6- Totally protected against dust
Second Number
Second Number
1- Protection against vertically falling drops of water (e.g. condensation)
2- Protection against direct sprays of water up to 15 degrees from vertical
3- Protection against direct sprays of water up to 60 degrees from vertical
4- Protection against water sprayed from all directions - limited ingress permitted
5- Protected against low pressure jets of water from all directions - limited ingress permitted
6- Protected against low pressure jets of water, limited ingress permitted (e.g. ship deck)
7- Protected against the effect of immersion between 15cm and 1m
8- Protected against long periods of immersion under pressure
tinhawk (威望:0) (上海 虹口区) 机械制造 经理
真的很不错, 专业人士啊. 佩服.
4 个回复,游客无法查看回复,更多功能请登录注册
tony61825
tony61825
我的理想是做一个超级设计师,所以来这里学习交流。
