國際標準與軍規之可靠度試驗標準
IEC 標準號碼/ 標準名稱 /出版年
61586 Estimation of the reliability of electrical connectors 1997
61650 Reliability data analysis techniques - Procedures for comparison of two constant failure rates and two constant failure (event) intensities 1997
61703 Mathematical expressions for reliability, availability, maintainability and maintenance support terms 2001
61709 Electronic components - Reliability - Reference conditions for failure rates and stress models for conversion 1996
61751 Laser modules used for telecommunication - Reliability assessment 1998
62005-1 Reliability of fibre optic interconnecting devices and passive components - Part 1: Introductory guide and definitions 2001
62005-2 Reliability of fibre optic interconnecting devices and passive components - Part 2: Quantitative assessment of reliability based on accelerated ageing test - Temperature and humidity; steady state 2001
62005-3 Reliability of fibre optic interconnecting devices and passive components - Part 3: Relevant tests for evaluating failure modes and failure mechanisms for passive components 2001
62005-4 Reliability of fibre optic interconnecting devices and passive optical components - Part 4: Product screening 1999
60319 Presentation and specification of reliability data for electronic components 1999
60605-1 Equipment reliability testing Part1:General requirements 1978
60605-2 Equipment reliability testing - Part 2: Design of test cycles 1994
60605-3-1 Equipment reliability testing. Part 3: Preferred test conditions. Indoor portable equipment - Low degree of simulation 1986
60605-3-2 Equipment reliability testing. Part 3: Preferred test conditions. Equipment for stationary use in weather protected locations - High degree of simulation 1986
60605-3-3 Equipment reliability testing - Part 3: Preferred test conditions - Section 3: Test Cycle 3: Equipment for stationary use in partially weather protected locations - Low degree of simulation 1992
60605-3-4 Equipment reliability testing - Part 3: Preferred test conditions - Section 4: Test cycle 4: Equipment for portable and non-stationary use - Low degree of simulation 1992
60605-3-5 Equipment reliability testing - Part 3: Preferred test conditions - Section 5: Test cycle 5: Ground mobile equipment - Low degree of simulation 1996
60605-3-6 Equipment reliability testing - Part 3: Preferred test conditions - Section 6: Test cycle 6: Outdoor transportable equipment - Low degree of simulation 1996
60605-4 Equipment reliability testing - Part 4: Statistical procedures for exponential distribution - Point estimates, confidence intervals, prediction intervals and tolerance intervals 2001
60605-6 Equipment reliability testing - Part 6: Tests for the validity of the constant failure rate or constant failure intensity assumptions 1997
60706-1 Guide on maintainability of equipment. Part 1 - Sections One, Two and Three. Introduction, requirements and maintainability programme 1982
60812 Analysis techniques for system reliability - Procedure for failure mode and effects analysis (FMEA) 1985
60863 Presentation of reliability, maintainability and availability predictions 1986
61014 Programmes for reliability growth 2003
61078 Analysis techniques for dependability - Reliability block diagram method 1991
61123 Reliability testing - Compliance test plans for success ratio 1991
61124 Reliability testing - Compliance tests for constant failure rate and constant failure intensity 1997
61163-1 Reliability stress screening - Part 1: Repairable items manufactured in lots 1995
61163-2 Reliability stress screening - Part 2: Electronic components 1998
61164 Reliability growth - Statistical test and estimation methods 2004
62005-7 Reliability or fibre optic interconnecting devices and passive optical components - Part 7: Life stress modeling 2004
62211 Inductive components - Reliability management 2003
TR 62048 Optical fibres - Reliability - Power law theory 2002
TR 62380 Reliability data handbook- Universal model for reliability prediction of electronics components, PCBs and equipment 2004
美軍軍規號碼 標準名稱(ACTIVE)
MIL-HDBK-109 QUALITY CONTROL AND RELIABILITY - STATISTICAL PROCEDURES FOR DETERMINING VALIDITY OF SUPPLIERS ATTRIBUTES INSPECTION OF
MIL-HDBK-189 RELIABILITY GROWTH MANAGEMENT
MIL-HDBK-217F RELIABILITY PREDICTION OF ELECTRONIC EQUIPMENT
MIL-HDBK-251 RELIABILITY/DESIGN THERMAL APPLICATIONS
MIL-HDBK-338B ELECTRONIC RELIABILITY DESIGN
MIL-HDBK-781A RELIABILITY TEST METHODS, PLANS, AND ENVIRONMENTS FOR ENGINEERING DEVELOPMENT, QUALIFICATION, AND PRODUCTION
MIL-HDBK-1823 NONDESTRUCTIVE EVALUATION SYSTEM, RELIABILITY ASSESSMENT
MIL-HDBK-2067 AIRCREW AUTOMATED ESCAPE SYSTEMS RELIABILITY AND MAINTAINABILITY (R/M) PROGRAM REQUIREMENTS FOR
MIL-STD-790F ESTABLISHED RELIABILITY AND HIGH RELIABILITY QUALIFIED PRODUCTS LIST (QPL) SYSTEMS FOR ELECTRICAL, ELECTRONIC, AND FIBER OPTIC PARTS SPECIFICATIONS
以下為美軍軍規網站:
http://assist.daps.dla.mil/quicksearch/
美軍軍規號碼 標準名稱(ACTIVE)
以下為美軍軍規網站:
4 个回复
marshall (威望:0) (广东 惠州) - 从事连接线行业,曾管理品保部、工程部。喜欢接爱新...
