求助:SPC实例操作
工厂程序文件规定ME每天对锡炉量测Profile, 由于人员不足, 现无法做到每天量测. 老板决定挑一示范线, 分时间段每天量测5次Profile并记录数据, 导入SPC管制以检测其稳定度, 最终目的是作为重新定义Profile量测频度的依据, 并要求实施前完成MSA
以下为收集了21天的数据, 每天五次, 每次产生三个监控点的数据: 焊锡面, 零件面和峰温.
请坛里的高手指点指点, TKS.
BY時間段Profile測試數據統計報表
時間段 日期08:00~10:0010:10~11:5013:10~15:3015:40~17:4018:30~20:30
焊錫面預熱 最高溫度零件面預熱 最高溫度峰溫焊錫面預熱 最高溫度零件面預熱 最高溫度峰溫焊錫面預熱 最高溫度零件面預熱 最高溫度峰溫焊錫面預熱 最高溫度零件面預熱 最高溫度峰溫焊錫面預熱 最高溫度零件面預熱 最高溫度峰溫
9月20日121.996.5243.8121.899.5243.8119.596.6243.895.96118.4242.2121.33100.13240.6
9月21日120.8497.92240.9120.8498.65240.9119.3796.2244.998.41121.45243.6121.0894.73244.4
9月22日121.798.41242.9122.92101.11244.9117.6598.6524396.08122.191242.9119.6194.49244
9月24日118.7594.73243.5118.7594.49241.9121.2196.64244.7118.5194.49243.4121.4598.41243.6
9月25日121.797.43232.2118.8899.51238.6119.9894.73235.2120.7297.31241.4121.296.9238.6
9月26日116.992.89242.1117.6591.6243.2120.2295.1242.8117.493.3242.6117.792.8246.2
9月27日121.797.43246.2121.9497.67244.7123.2998.2245.8121.796.57245.7122.3198.41243.3
9月28日119.794.6233.7117.6593.8243.2120.295.1242.8121.94102.9237.3121.5799.5236.8
10月08日123.1799.4236.5122.399.6237.3121.899.3233.7119.398.1242.5121.2100.1241.4
10月09日121.899.4236.8119.499.5231.6123.598.9236.7122.9102.4238.1124.1100.6231.1
10月10日121.2103.3232.7122.4103.3234.9120.7102.2238.1124.1100.6231.1122.9102.45238.1
10月11日121.4104.5235.1120.5101.7237.4122.9100.4236.5121.797.8238121.08102.9240.9
10月12日122.9102.7238121.899.3233.7122.3100240.6120.1100.4236.7122.9103.5237.4
10月13日120.9100235.1121.08104.4236.3120.1100.4236.7122.4102.8239.5121.4597.7239.6
10月15日125.8108.4234120.9103.7237.3123.5106.3234121.57103.1236.8121.4599.2236.3
10月16日122.5598.4232.4125.5105.3236.4124.7104.5232.7115.892.5236.7122.395.8238.5
10月17日122.19102.3238122.6103.07237.4123.4105.27236.5121.799.2233.7122.06104.5240.6
10月18日120.1100.4236.7120.194.61235.9122.8103.1242.5123.1103.6235.8121.4598.4234.4
10月19日123.17105.6236.4122.8104.5240.9119.694.49235.2122.68102.2238.1121.2103.4234.9
10月22日123.41100.37234.9124.2102.33233120.3599.76235.8122.19107.1231.8118.292.8231.6
10月23日123.497.43234.1123.17103.3234.9126.48106.8235.7123.66102..33235.8121.94103.3232.2
请坛里的高手指点指点, TKS.
4 个回复
王海友 (威望:1) (江苏 徐州) 机械制造 经理 - 六西格玛项目管理
2、SPC是建立在过程能力稳定及达标的情况下来做的,所以这一步你要做CPK,保证过程能力达标(大于1比较合适);
3、如果不达标马上启动项目进行改善;
4、改善完成后在进行分析用控制图建立控制线;
5、实施SPC
上述只是简单的描述了一下,希望对你有帮助!
