请大家帮我看看这两个外审不符合项如何回复比较适当
问题一:
At the time of audit by 12:15am at Assembly workshop; it was found that the in-process inspection records were duly filled before the required time interval of inspection time at 14:30 and 16:30pm.
在装配车间审核通过的时间是12:15,结果发现,过程中的检查记录,提前填写好的检查时间为14:30和16:30不是所要求的时间间隔。
The QA FQC inspection Standards LUK’s-WI-111 V4.0 showed that there were no FQC report retained necessary, which was violated the requirement of QM8.2.4 of QMS Manual, actually the selected QA reports of some final inspection were not provided; e.g. T7779; T2889 etc.
QA FQC检验标准LUK's-WI-111 V4.0表明,FQC并没有保留必要的报告,这是违反QM8.2.4手册,质量管理体系的要求,实际上是选择的QA报告并没有提供一些最后的检查,例如T7779,T2889等。
问题二:
Some QC staff could not understand the GB/2828-2003; e.g. the lot size :5 rolls and the sampling size should be 5 Rolls according to AQL 1.5, level II of GB 2828 -2003, but actually it was selected 2 rolls only
一些QC工作人员无法理解GB/2828-2003(计数抽样检验程序);根据AQL(接收质量限)1.5,II级GB 2828-2003的批量:5卷和采样大小应该是5卷,但实际上它是只选择2卷。
谢谢!
history123 (威望:18) (广东 东莞) 电子制造 工程师 - 质量管理及改善
你这明显的作假,还真是不好写。回去好好考虑一下。
4 个回复,游客无法查看回复,更多功能请登录注册
