尺寸链的计算-tolerance stacking calculation
请教各位前辈,如下为一个计算累计公差的表格,本人有几点问题想请教,忘各位指点:
1、表格中的factor值是怎样算的?
2、为什么每行中σ 的计算方法为半公差限/6*factor值
3、上、下行数据链UDL\LDL的计算公式为何为mean值+/-6*sum的σ 值
4、 Above target以及 Below targe是怎样算的
以上几点希望理解的前辈指导一下,thanks。
  Design Target for Gap: 0.7 ± 0.30 Unit: mm Part
  Before Coating Assemble
Upper Hinge Data from XXXXX
Item. Part Dimension Design (After thinking about the mean has 1.5σ shift)
Mean Tolerance Factor σ
1 Cavity Hinge upper A1: Rotaion hole to fixed plate 25 ± 0.150 1 0.0250
2 Front plate rivet C1: Front plate thickness 0.7 ± 0.020 1 0.0033
B1: Welding gap btwn front plate and hinge 0.3 ± 0.100 1 0.0167
3 Uper pivot alignment Door Hinge align hole 0 ± 0.050 0 0.0000
Cavity hinge align hole 0 ± 0.050 0 0.0000
D1: Assemble gap with Cavity hinge 0 ± 0.150 0.5 0.0125
E1: Assemble gap with Door hinge 0 ± 0.150 0.5 0.0125
4 Door Hinge upper F1: Rotation hole to base plate 1.2 ± 0.200 1 0.0333
5 Metal door G: Thickness of metal door 22 ± 0.200 1 0.0333
H1:Thickness of powder coating 0.1 ± 0.015 1 0.0025
  Sum Mean= 0.7 σ= 0.0587
  Min= 0.5238
  Max= 0.8762
  Range= 0.3523
  Upper Cpk= 1.7029
  Lower Cpk= 1.7029
  Cpk= 1.7029
  Cp = 1.7029
UDL = 1.0523
  LDL = 0.3477
  Out of spec PPM
  Above target 153.9462
  Below target 153.9462
  Total rate out of limit 307.8923
  PPT= 0.3079
A1=B1+C1+gap+H1+G1+F1+E1+D1
楼主,这个东东的出处是哪里的?。。。。。建议直接向出处的编制人讨教。。。。。。
2 个回复,游客无法查看回复,更多功能请登录注册
zhou87year
zhou87year
质量工程师
