Minitab 16.2.4.0 新版发布!特别文件
分享如下信息!
英文语言包
http://fs1.minitab.com/prodins ... p.exe
中文语言包
单用户中文安装包
http://fs1.minitab.com/prodins ... u.exe
单用户英文安装包
多用户中文安装包
多用户英文安装包
特别文件
到下面去看看。
http://uploaded.net/file/hnxu592b
http://rapidgator.net/file/a14 ... 1eae1
Part 8. Problems Resolved in Minitab 16.2.4
Several specific issues have been resolved in Minitab 16.2.4, including:
Item 1
When the response column for a split-plot factorial design contains missing values, Stat > DOE >
Factorial > Analyze Factorial Design may calculate incorrect fits and whole plot residuals.
(169035)
Item 2
The contour plot for a split-plot factorial design shows incorrect values when blocks and an
interaction term that includes a plotted variable are in the model. (169152)
Item 3
When a text factor in a split-plot factorial design contains one or more missing values, the
coefficient for that factor and its interactions may be incorrect. Specifically, they are erroneously
multiplied by (-1). (169193)
Item 4
In a split-plot factorial design, Stat > DOE > Factorial > Analyze Variability > Storage may yield
a run-time exception error. (169343)
Item 5
General Linear Model incorrectly calculates values in the ANOVA table when a covariate is
nested within a factor, and the order in which covariates were entered into the Model field does
not match the order in which they were entered into the Covariates subdialog box. (169117)
Item 6
When you create a T Chart with stages and one value for the historical scale parameter, Minitab
may crash, or Minitab may ignore the specified historical scale value. (169082)
Item 7
After closing a worksheet using the Project Manager, Minitab may still display the deleted
worksheet in the Window menu. Selecting the worksheet produces a run-time exception error.
(129570)
Item 8
If a CSV file is saved in one Minitab session, and then re-opened and re-saved in a second
Minitab session, the resulting CSV file will not be able to be opened by Minitab again using the
default import settings. (169250)
Item 9
Send to Microsoft Word yields run-time exception errors and may crash Minitab when Word is set
to display documents in Full Screen Reading mode. (166667)
Item 10
Send to Microsoft Word yields assertion failure errors when Word is set to display documents in
Preview mode. (169331)
第 8 部分. Minitab 16.2.4 中已解决的问题
Minitab 16.2.4 解决了多个特定问题,包括:
项目1
在裂区因子设计的响应列中包含缺失值时,统计 > DOE > 因子 > 分子因子设计可能会计算出不正
确的拟合值和整区残差。 (169035)
项目 2
在包含已标绘变量的区组和交互作用项位于模型中时,裂区因子设计的等值线图显示不正确的值。
(169152)
项目3
在裂区因子设计中的文本因子包含一个或多个缺失值时,该因子及其交互作用的系数可能不正确。
尤其是,它们错误地乘了 (-1)。 (169193)
项目 4
在裂区因子设计中,统计 > DOE > 因子 > 分析变异性 > 存储可能会产生运行时异常错误。
(169343)
项目 5
在协变量嵌套在因子中,并且将协变量输入到“模型”字段中的顺序与将协变量输入到“协变量”子对
话框中的顺序不匹配时,一般线性模型会错误地计算方差分析表中的值。 (169117)
项目 6
在利用阶段和历史尺度参数的一个值创建 T 控制图时,Minitab 可能会崩溃,或者,Minitab 可能会
忽略指定的历史尺度值。 (169082)
项目 7
在使用 Project Manager 关闭工作表时,Minitab 仍会在“窗口”菜单中显示已删除的工作表。选择此
工作表会产生运行时异常错误。 (129570)
项目 8
如果在一个 Minitab 会话中保存了一个 CSV 文件,然后在另一个 Minitab 会话中再次保存该文件,
则 Minitab 无法使用默认的导入设置再次打开所保存的 CSV 文件。 (169250)
项目 9
“发送到 Microsoft Word”会产生运行时错误,并且,在将 Word 设置为在“全屏读取”模式下显示文
档时,Minitab 可能会崩溃。 (166667)
项目 10
在将 Word 设置为在“预览”模式下显示文档时,“发送到 Microsoft Word”会产生声明失败错误。
(169331)
分享如下信息!
英文语言包
中文语言包
单用户中文安装包
单用户英文安装包
多用户中文安装包
多用户英文安装包
特别文件
到下面去看看。
Item 1
(169035)
Item 2
Item 3
Item 4
Item 5
Item 6
Item 7
(129570)
Item 8
Item 9
Item 10
项目1
项目 2
(169152)
项目3
项目 4
(169343)
项目 5
项目 6
项目 7
项目 8
项目 9
项目 10
(169331)
0 个回复
