哪个帮我译一下啊?我不会,谢谢
Nodularity Check
1) Preparation of nodularity sample is very poor and difficlt to read the nodularity.
Sample size to be increased or define Standard size of samples and it should be taken at last pour of mould per every treatment.
2) Spectro samples are taken only random laddles to check chemistry & Mg% (6treated laddles are poured per each 6ton of furnace metal), Recommend to take it at last pour of mould per every treatment to ensure Mg%.
Traceability of Nodularity
1) There is no visual identification mark or flag system on mold line for each treated batch and very less possibilities to separate a batch with low nodularity.
2) No Quarantine/rejection area at cooling or knock-out area to separte if any batch with low nodularity.
Hardness measurement
1) No practice to measure hardness on few of QT parts , generally hardness to be measured on all production parts with defined frequency .
2) No calibration of Hardness equipment by using master sample, Evidenced referance value of Master sample is 217BHN, but calibration value of machine is 206BHN - equipment to be re-calibrated.
尚和小 (威望:14) (江苏 苏州) 汽车制造相关 主管
结节状态检查
1)制备结节样很差,困难的阅读结节。
样本量增加或定义标准尺寸的样品,应采取最后倒模具每治疗。
2)斯派克样品只采取随机laddles检查化学&毫克%(6治疗laddles是倒每6吨炉的金属),建议把它最后倒模具每治疗以确保毫克%。
可追溯性的结节
1)没有视觉识别标志或标志系统为每个处理模具行批处理和非常少的可能性较低的单独的一批结节。
2)没有检疫/拒绝区域冷却或淘汰赛区域separte如果任何批结节较低。
硬度测量
1)没有实践测量硬度的QT部分,一般硬度测量在所有生产部分定义的频率。
2)没有硬度的校准设备通过使用标准样品,证明refera
2 个回复,游客无法查看回复,更多功能请登录注册
心悟
心悟
初学
