客户提供的抽样标准不能理解,请高手赐教。
各位好,收到客户发来的抽样标准的要求,和之前接触过的不相同,详见下记描述。请高手解释怎么运用,或者有什么标准可以参照。非常感谢!
The way we would judge Accept or Reject is this. Your inspector will be inspecting a number of "top of lid" and "main body of case" and will determine the quantity of inspected parts that fail. Then multiply the number of inspected parts by 0.025 to calculate the maximum number of Major Fail allowed, based on the sample inspected. Also multiply the number of inspected parts by 0.04 to calculate the maximum number of Minor Fail allowed. If the actual number of Major Fail parts is higher than the calculated maximum number Major Fail allowed, then the work is Reject. If the actual number of Minor Fail parts is higher than the calculated maximum number Minor Fail allowed, then the work is Reject. If both actual numbers are under the maximum allowed, the work is Accept.
3 个回复
stephenma (威望:0) (上海 南汇区) 机械制造 经理
赞同来自: sv1912
