以下供参考:
1 Battery and cover insert/remove test
2 Button test
3 SIM card insert/remove test
4 Micro SD card insert/remove test
5 USB Plug in/out test
6 Battery life time test
7 Main battery charge current test
8 Voltage margin test
9 RTC retention time test
10 Audio durability test
11 Camera test for focus, resolution, gray level
12 Power on/off test
13 Boot test
14 Luminance Measurement
15 Thermal cycling test
16 High Temp/Humidity Cycle test
17 Thermal shock test
18 Storage test
19 Short distance drop
20 Vibration test operating (no-package)
21 LCM compress test
22 Drop test (Non- package)
23 Drop test for stylus
24 Drop test for Battery
25 EMS (ESD) TEST
26 EMI TEST
27 SAR test (Specific Absorption Rate)
4 个回复
charlessteven (威望:136) (湖北 武汉) 电信通讯 XX
2 Button test
13 Boot test
18 Storage test
25 EMS (ESD) TEST
26 EMI TEST
