模具工程常用词汇
die 模具
figure file, chart file图档
cutting die, blanking die冲裁模
progressive die, follow (-on)die
连续模
compound die复合模
punched hole冲孔
panel board镶块
to cutedges=side cut=side scrap切边
to bending折弯
to pull, to stretch拉伸
Line streching, line pulling线拉伸
engraving, to engrave刻印
upsiding down edges翻边
to stake铆合
designing, to design设计
design modification设计变化
die block模块
folded block折弯块
sliding block滑块
location pin定位销
lifting pin顶料销
die plate, front board模板
padding block垫块
stepping bar垫条
upper die base上模座
lower die base下模座
upper supporting blank上承板
upper padding plate blank上垫板
spare dies模具备品
spring 弹簧
bolt螺栓
document folder文件夹
file folder资料夹
to put file in order整理资料
spare tools location手工备品仓
first count初盘人
first check初盘复棹人
second count 复盘人
second check复盘复核人
equipment设备
waste materials废料
work in progress product在制品
casing = containerazation装箱
quantity of physical invetory second count 复盘点数量
quantity of customs count
会计师盘,点数量
the first page第一联
filed by accounting department for reference会计部存查
end-user/using unit(department)使用单位
summary of year-end physical inventory bills
年终盘点截止单据汇总表
bill name单据名称
This sheet and physical inventory list will be sent to accounting
department together (Those of NHK will be sent to financial
department)
本表请与盘点清册一起送会计部-(NHK厂区送财会部)
Application status records of year-end physical inventory List and
physical inventory card 年终盘点卡与清册使用-状况明细表
blank and waste sheet NO.
空白与作废单号
plate电镀
mold成型
material for engineering mold testing工程试模材料
not included in physical inventory不列入盘点
sample样品
incoming material to be inspected进货待验
description品名
steel/rolled steel钢材
material statistics sheet
物料统计明细表
meeting minutes会议记录
meeting type 会别
distribution department分发单位
location地点
chairman主席
present members出席人员
subject主题
conclusion结论
decision items决议事项
responsible department负责单位
pre-fixed finishing date预定完成日
approved by / checked by / prepared by核准/审核/承办
PCE assembly production schedule sheet
PCE组装厂生产排配表
model机锺
work order工令
revision版次
remark备注
production control confirmation生产确认
checked by初审
approved by核准
department部门
stock age analysis sheet
库存货龄分析表
on-hand inventory现有库存
available material良品可使用
obsolete material良品已呆滞
to be inspected or reworked
待验或重工
total合计
cause description原因说明
part number/ P/N 料号
type形态
item/group/class类别
quality品质
prepared by制表
notes说明
year-end physical inventory difference analysis sheet
年终盘点差异分析表
physical inventory盘点数量
physical count quantity帐面数量
difference quantity差异量
cause analysis原因分析
raw materials原料
materials物料
finished product成品
semi-finished product半成品
packing materials包材
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods处理品
warehouse/hub仓库
on way location在途仓
oversea location海外仓
spare parts physical inventory list备品盘点清单
spare molds location模具备品仓
skid/pallet栈板
tox machine自铆机
wire EDM线割
EDM放电机
coil stock卷料
sheet stock片料
tolerance工差
score=groove压线
cam block滑块
pilot导正筒
trim剪外边
pierce剪内边
drag form压锻差
pocket for the punch head挂钩槽
slug hole废料孔
feature die公母模
expansion dwg展开图
radius半径
shim(wedge)楔子
torch-flame cut火焰切割
set screw止付螺丝
form block折刀
stop pin定位销
round pierce punch=die button圆冲子
shape punch=die insert异形子
stock locater block定位块
under cut=scrap chopper清角
active plate活动板
baffle plate挡块
cover plate盖板
male die公模
female die母模
groove punch压线冲子
air-cushion eject-rod气垫顶杆
spring-box eject-plate弹簧箱顶板
bushing block衬套
insert 入块
club car高尔夫球车
capability能力
parameter参数
factor系数
phosphate皮膜化成
viscosity涂料粘度
alkalidipping脱脂
main manifold主集流脉
bezel斜视规
blanking穿落模
dejecting顶固模
demagnetization去磁;消磁
high-speed transmission高速传递
heat dissipation热传
rack上料
degrease脱脂
rinse水洗
alkaline etch龄咬
desmut剥黑膜
D.I. rinse纯水次
Chromate铬酸处理
Anodize阳性处理
seal封孔
revision版次
part number/P/N料号
good products良品
scraped products报放心品
defective products不良品
finished products成品
disposed products处理品
barcode条码
flow chart流程表单
assembly组装
stamping冲压
molding成型
spare parts=buffer备品
coordinate座标
dismantle the die折模
auxiliary fuction辅助功能
poly-line多义线
heater band 加热片
thermocouple热电偶
sand blasting喷沙
grit 砂砾
derusting machine除锈机
degate打浇口
dryer烘干机
induction感应
induction light感应光
response=reaction=interaction感应
ram连杆
edge finder巡边器
concave凸
convex凹
short射料不足
nick缺口
speck瑕??
shine亮班
splay 银纹
gas mark焦痕
delamination起鳞
cold slug冷块
blush 导色
gouge沟槽;凿槽
satin texture段面咬花
witness line证示线
patent专利
grit沙砾
granule=peuet=grain细粒
grit maker抽粒机
cushion缓冲
magnalium镁铝合金
magnesium镁金
metal plate钣金
lathe车
mill锉
plane刨
grind磨
drill铝
boring镗
blinster气泡
fillet镶;嵌边
through-hole form通孔形式
voller pin formality滚针形式
cam driver铡楔
shank摸柄
crank shaft曲柄轴
augular offset角度偏差
velocity速度
production tempo生产进度现状
torque扭矩
spline=the multiple keys花键
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
tungsten high speed steel钨高速的
moly high speed steel钼高速的
organic solvent有机溶剂
bracket小磁导
liaison联络单
volatile挥发性
resistance电阻
ion离子
titrator滴定仪
beacon警示灯
coolant冷却液
crusher破碎机
模具工程类
plain die简易模
pierce die冲孔模
forming die成型模
progressive die连续模
gang dies复合模
shearing die剪边模
riveting die铆合模
pierce冲孔
forming成型(抽凸,冲凸)
draw hole抽孔
bending折弯
trim切边
emboss凸点
dome凸圆
semi-shearing半剪
stamp mark冲记号
deburr or coin压毛边
punch riveting冲压铆合
side stretch侧冲压平
reel stretch卷圆压平
groove压线
blanking下料
stamp letter冲字(料号)
shearing剪断
tick-mark nearside正面压印
tick-mark farside反面压印
冲压名称类
extension dwg展开图
procedure dwg工程图
die structure dwg模具结构图
material材质
material thickness料片厚度
factor系数
upward向上
downward向下
press specification冲床规格
die height range适用模高
die height闭模高度
burr毛边
gap间隙
weight重量
total wt.总重量
punch wt.上模重量
五金零件类
inner guiding post内导柱
inner hexagon screw内六角螺钉
dowel pin固定销
coil spring弹簧
lifter pin顶料销
eq-height sleeves=spool等高套筒
pin销
lifter guide pin浮升导料销
guide pin导正销
wire spring圆线弹簧
outer guiding post外导柱
stop screw止付螺丝
located pin定位销
outer bush外导套
模板类
top plate上托板(顶板)
top block上垫脚
punch set上模座
punch pad上垫板
punch holder上夹板
stripper pad脱料背板
up stripper上脱料板
male die公模(凸模)
feature die公母模
female die母模(凹模)
upper plate上模板
lower plate下模板
die pad下垫板
die holder下夹板
die set下模座
bottom block下垫脚
bottom plate下托板(底板)
stripping plate内外打(脱料板)
outer stripper外脱料板
inner stripper内脱料板
lower stripper下脱料板
(威望:)
向楼主致敬,感谢无私奉献!
3 个回复,游客无法查看回复,更多功能请登录注册
