关于粗糙度的一些问题,望各位大大能帮小弟解决
昨天的帖子被删了应该是发错地方了,这次不用删了吧.....
小弟手上有一张图档(来自德国),其表面粗糙度标注为Rmax20以及Rmax20*
其测量方法如下:
the surface roughness can max. Ra=20 (acc. to DIN ISO 1302), material separating is allowed
the note means: in a total length of ...mm You measure x segments with a segment length of ... mm
==> ** measurement length is 4.0mm, measurement segment is 0.8, count of segments is 4
==> *** measurement length is 4.0mm, measurement segment is 0.8, count of segments is 3
不知道有没大哥对德国DIN标准有所了解,小弟想弄明白到底图纸要求的粗糙度是多少,国内表示为Ra3.2,Ra1.6 ,Ra0.4等..请指教,感激不尽~~
0 个回复,游客无法查看回复,更多功能请登录注册
