谁知道这个知识点考的是啥
Devise a sampling plan for obtaining a representative BTU sample from an open top railcar of coal, where the contents are known to have changed and also stratified due to vibration and exposure during the 10 days of shipment.
A.Draw a slipstream sample by taking a representative slice of the bulk material as the car is being unloaded, being certain to capture all of the generated dust.
B.Receive a certificate of analysis from the supplier of a sample properly collected from the entire load at the time of loading, knowing that the coal got wet and dust blew off the open railcar.
C.Draw a quota sample with one sample off the top and from five more standardized depths in the railcar.
D.Draw a convenience sample from multiple points that can be easily accessed.
CAHH999 (威望:29) (广东 东莞) 汽车制造相关 经理 - years experience on qual...
看起来好像是,因为煤在10天的运输过程中,由于震动和裸露在空气中,造成了变化和分层。请设计一个合理的抽样计划来获得有代表性的BTU。
所以,考点应该是怎样抽样才可以保证获得最可靠的BTU数据来反映该车皮的煤的实际BTU值。
感觉上C好像靠谱些?
xuexidoe
xuexidoe
分析
