欧盟将在2017年加大对SDS监控要求,各位将如何应对?
引用某公证行部分信息:
赫尔辛基2017年1月10日消息,28个欧盟及欧洲经济区成员国的执法机构将开始审查供应链内部危险化学品的安全信息的符合性、是否有效传递以及在工作场所的遵从情况,该工作的核心内容即对安全数据表(SDS)的质量进行核查。
        各国执法机构的检查员将核实拓展的安全数据表的信息是否与物质生产商准备的化学安全报告(CSRs)相匹配。该执法行动也将核查安全数据表传递、及在供应链沟通的有效性,确保工人能够获得充足且正确的信息,安全地处理危险化学品,尤其是高关注物质。
        执法机构的检查员还将与检查员还将与劳动检察员共同协作,检查工人是否严格遵从传递的安全信息进行操作,并进行风险控制。
        本次执法行动是REACH执法项目REF-5,于2015年年末被ECHA的执法信息交流论坛采纳,第一次审查将于2017年1月份开展,并贯穿一整年。审查报告预计于2018年第4季度完成。该执法行动是欧盟首次联合执法计划,旨在通过安全数据表提升供应链内部的交流及信息传递。
欧盟官方信息:
Chemical safety for workers targeted by next EU enforcement project
ECHA/PR/17/01
Enforcement authorities in the EU will inspect how safety information on hazardous chemicals is compiled, communicated in the supply chain and followed at workplaces.
Helsinki, 10 January 2017 – The safety of workers will be inspected by 28 EU and EEA Member States. The key element of the project will be to investigate the quality of the safety data sheets that contain guidelines on the safe use of hazardous substances.
Inspectors will check if the extended safety data sheets match the information established by the chemical safety reports (CSRs) that substance manufacturers prepare. They will also go through the exposure scenarios attached to the safety data sheets. An exposure scenario describes the amount and character of exposure to its hazards when a substance is manufactured or used for its destined purposes. It also advises how the exposure of humans and release to the environment can be controlled.
One of the objectives of this enforcement project is to ensure that workers handling hazardous chemicals, especially those dealing with substances of very high concern, receive sufficient and correct safety information. The project will also map how effectively extended safety data sheets are passed on and communicated all the way through the supply chain, i.e. from manufacturers of chemicals to the users.
Inspectors will furthermore check whether workers actually respect the safety information at their workplaces. Inspectors from national enforcement authorities will collaborate with labour inspectors to assess if the recommended operational conditions and risk management measures are fulfilled.
The REF-5 project was adopted by ECHA’s Forum for Exchange of Information on Enforcement at the end of 2015. The first inspections will take place in January 2017, and the activity will continue throughout the year. A report on the results of the inspections will be available in the fourth quarter of 2018.
The project will be the first joint EU enforcement project that aims to improve communication, through safety data sheets, throughout the supply chain.
据上述信息得知,欧盟将在2017年加大对SDS的监控力度,在此发文本意也是希望能请教各位管理人员对此有何高见,未来应对方法,及贵司在目前应对SDS的实际做法。或针对下列几点作为问题引荐:
A:加大监控力度,对贵司所在的行业影响大吗,为什么呢?
B:目前贵司对SDS的要求是什么,每个物料都要求供应商提供吗?
C:加大监控力度,贵司将如何应对?
D:鉴于本职工作,贵司将如何处理?
鉴于首期发文我将先行发表,愿能抛砖引玉,感谢各位畅所欲言。
我所在的公司为玩具制造业,当得知此个信息时我是一愣,因为截至目前SDS的监控依然属监控薄弱环节。但后来细想鉴于SDS原本监控重点便是“化学品”,我认为对我所在行业影响不大。
而SDS暂时管控要求是:
化学品类别(如,油漆,开油水、胶水等)、原料类别(色粉、各式胶料)要求供应商必须提供,至少每个系列需要提供一份,未来做法是要求每个物料编号持有一份SDS。
五金类(螺丝、弹簧、铁轴)、电子类(贴片电阻、电感、马达、喇叭、电池、电线、锡线等)均要求供应商按物料类别提供(既是镀镍螺丝一份、镀锌螺丝一份、镀镍弹簧一份、马达一份、喇叭一份),未来做法是要求电子类物料再细化监控要求
包装类(彩盒、彩卡、贴纸、包装绳)、毛绒布料类(各式布料)、各式辅料(车缝线、唛头、丝带、磁铁等),此个最是繁琐,只在新增新供应商时监控并要求提供SDS及BOS,否则不予以通过,后面来料因要求不统一,维持的只是部分有提供,未来做法将统一上述监控要求。
收到每份SDS/BOS,检验所有物资是否有存在于SVHC、CHCC及EC 1272:2008中,如有要求更改或要求不予以放行采购。同时要求提供相关物料测试报告,如RoHS、HE、PAE、PAHs、AZO、TPCH等
SDS细化监控也是2017年工作重点的一部分,希望能顺利开展。再次感谢各位到访、提出您宝贵意见!!!
不错,你都写了这么多,我是来学习的:P
