升温曲线如何设置控制限?
做化学实验时,随着时间的推移,反应温度不断升高,升到某个温度就会慢慢开始降温,想知道这种升温曲线如何设置控制限?下面是我的实验数据,每半个小时记一次温度。想知道如何设置控制限?求教~~~~
第1次实验 第2次实验 第3次实验 第4次实验 第5次实验 第6次实验 第7次实验 第8次实验 第9次实验 第10次实验
16.0  5.0  15.9  14.5  10.9  26.1  9.9 10.5 20.0  12.2
17.2  9.1  17.0  19.8  27.2  37.0  13.5 12.3 34.5  22.5
32.2  12.5  16.3  21.7  38.0  34.3  32.1 16.2 39.7  39.0
35.7  19.0  20.5  35.4  39.9  33.1  38.3 19.1 36.5  40.3
37.2  30.6  36.3  39.5  40.4  34.7  40.9 21 33.3  40.9
38.6  37.1  39.1  40.3  40.6  36.2  41.3 24.1 34.4  41.0
39.7  39.3  39.1  40.6  40.8  38.2  41.3 36.1 39.7  41.3
40.0  40.2  39.4  41.1  40.9  40.0  41.3 37.7 40.2  41.5
40.9  40.4  39.2  41.5  41.3  40.2  42.4 40.6 40.4  41.3
41.2  40.7  38.9  41.9  41.5  40.5  42.8 40.6 40.4  42.0
41.6  40.9  41.8  42.4  41.7  41.1  43 41.3 40.5  42.4
41.8  41.2  42.3  42.8  42.0  41.2  43.2 41.8 41.1  43.6
42.2  41.6  42.7  43.1  42.2  41.3  43.9 42.3 41.3  43.1
42.6  41.9  39.2  43.3  42.7  41.5  44.3 42.5 41.7  43.2
42.9  42.3  40.9  43.5  42.8  41.8  44.5 42.7 42.0  43.7
43.3  42.6  42.5  43.8  43.5  41.7  44.8 42.6 42.2  44.1
43.7  42.9  39.3  44.0  43.7  41.0  45.6 42.7 42.5  44.3
44.1  43.2  42.0  44.3  43.9  39.2  45.7 43.5 43.0  44.3
44.4  43.5  42.6  44.5  44.3  39.1  46.8 44 43.2  43.4
44.9  43.9  45.7  44.9  44.5  39.4  46.9 44.2 43.6  45.8
45.4  44.3  41.7  45.2  44.7  40.3  47.4 44.8 44.1  46.6
45.9  44.8  39.3  45.8  45.6  39.9  48 45.5 44.5  47.3
46.5  45.2  38.9  45.9  45.7  39.0  48.6 44.6 44.9  47.8
47.0  45.6  41.8  46.2  45.9  33.0  49.6 45.5 45.4  48.4
47.6  46.2  42.7  46.8  46.7  34.2  49.9 46.2 46.1  49.1
48.3  46.7  45.2  47.1  47.0  41.8  50.7 46.1 46.6  50.1
48.9  47.3  45.3  47.3  47.2  43.2  51.6 46.2 47.3  50.7
49.5  47.8  47.3  47.8  48.2  30.3  52.2 46.2 47.9  51.8
50.2  48.6  47.0  48.1  48.5  36.0  52.9 47.9 48.6  52.4
50.9  49.0  48.4  48.7  48.8  42.8  53.6 48.6 48.8  53.2
52.4  50.0  47.6  49.7  49.4  42.1  54.9 49.6 49.4  54.2
52.9  50.7  48.0  50.5  50.2  43.7  55 50.2 49.8  55.5
53.3  51.3  48.6  51.4  50.7  45.2  56.7 49.8 51.3  56.4
54.2  52.0  49.6  52.4  51.7  45.7  57 46.6 51.6  57.7
54.9  53.0  50.9  53.0  52.0  45.9  58.7 47.3 52.6  58.9
55.7  53.6  51.2  53.8  53.1  46.2  61.3 51 53.0  59.4
56.3  54.8  52.0  54.7  53.6  47.0  62.6 52.1 53.6  60.7
56.9  55.4  51.7  55.7  53.8  47.4  62.5 52.7 54.6  61.8
57.4  56.4  51.6  56.5  54.9  47.6  62.6 54 55.1  62.5
58.0  57.5  51.9  56.6  55.3  48.1  62.8 54.4 55.9  62.9
58.3  60.7  51.8  58.7  55.5  48.4  62.6 55.6 56.4  65.5
58.2  62.0  51.8  59.3  56.1  48.9  62.6 57 56.7  68.8
57.9  63.0  51.8  60.2  56.7  50.0  62.8 57.6 52.8  70.6
57.9  63.9  52.1  60.4  57.1  50.4  62.9 58.5 51.5  71.9
52.5  65.0  52.0  60.6  57.1  51.5  62.4 59.1 52.9  72.7
50.8  65.0  52.4  61.1  57.2  52.1  61.9 59.7 58.3  73.1
51.8  64.8  51.9  61.2  57.6  52.7  61.4 60.4 65.1  72.7
54.5  64.6  51.8  61.3  59.0  53.3  60.8 60.9 67.2  70.4
56.9  63.8  53.8  61.5  62.0  54.1  60.2 61.6 67.3  68.4
58.5  62.9  56.8  61.1  65.0  54.9  59.3 61.8 66.8  66.0
59.2  61.6  65.0  53.9  66.9  55.3  58.2 62.2 67.0  64.0
59.7  60.1  63.1  57.3  68.0  56.4  56.1 61.9 66.8  60.9
59.9  55.0  61.7  61.3  68.2  56.6  53.4 61.7 66.3  56.9
59.7  51.4  60.7  64.9  68.1  57.3  61.4 66.2
59.4  48.1  59.8  63.4  49.5  60.9
58.6  47.1  58.7  62.9  48.2  60.6
46.4  57.8  51.5
uogo (威望:18) (上海 上海) 汽车制造相关 供应商质量工程师
赞同来自: miksa
温度控制在我们SMT的过程控制上是很普遍的,通常都是画出一个温度随时间变化的上下限,用两条温度曲线中间夹一个控制区间。
我尝试把你的数据拿来画图,发现一个很严重的问题,就是记时起点的不固定,这与我们的时间和设备位移有强相关是不同的。所以在处理数据的时候还要先对起点作一个确定,比如从温度达到15度时开始计算?
如果这个温度起点是化学反应本身造成的,那我想是不是可以先固定一个反应开始条件,比如先把反应环境调整到15度,再开始。
2 个回复,游客无法查看回复,更多功能请登录注册
mafly87
mafly87
heh
