方差分析中计算出均方,再通过均方得得的SD,怎么计算出SD的95%置信限,mintab怎么操作
如图
杨格_Alan (威望:668) (江苏 无锡) 机械制造
赞同来自: Young120
Bonferroni confidence intervals
Minitab calculates confidence intervals for the standard deviations using the Bonferroni method. A confidence interval is a range of values that is likely to include some population parameter, in this case, contain the standard deviation.
Standard confidence intervals are calculated using a confidence level 1 – α / 2. the Bonferroni method uses the confidence level 1 – α / 2p for each individual confidence interval, where p is the number of factor and level combinations. The method ensures that the set of confidence intervals has a confidence level of at least 1 – α. The Bonferroni method provides more conservative (wider) confidence intervals, which reduces the probability of a type 1 error.
