英语高手帮帮忙啊
外国老头发了封信看懂了大概的,具体的搞不大清楚,有米有高手帮帮忙指点一下啊
We conclude that many of the failures were not at the solder joint but did break between the 34AWG fine wire solder joint and the point where it exits the coil. I wanted to know if there is anything we can do to enhance the fine wire durability from the Baibang coil.
There is Baibang handling after the spool is filled, to tape, to mark, to do final electrical test, and ship. I don't know how many times that extra lead out wire is manipulated. Please examine your process and discuss you findings.
A difference may exist between wire strength or durability of a varnish only wire, and the solder tinned wire. My experiment was a bend test of the 34AWG wire from a 201927-001 part;
I cut the lead out wire on old coils with most of length has varnish only and the tip was solder tinned
The tip was clamped in a rubber vise forming a loop so mild tension on the wire was equal to both the tinned and untinned tip.
I held a light tension ( 1 ounce) pull at the loop and counted 90 degree bends both ways from vertical in the vise held wire.
Results were 70% broke in the solder tinned wire at 25 to 30 bends.
The 30% that broke in the varnish end first had very few remaining bends left before the tinned end broke.
I clamped 2 loops with varnish only at both clamped ends and was able to count 50 - 60 bends before one varnish end broke.
- We have accumulated results on the assembly failures for the CSD unit that shows the highest field failure rate is caused by the electrical tap connection inside the potted and taped area from coil to the solder harness.
- What source is that 34AWG wire, restate who are the sources if more than one.
- How would you explain the tinned wire portion as being not as durable Extra heat process affecting the wire
- Comment on conclusion to make more wire stay varnish with only needed tinning at tip. This is now being tinned almost to edge of plastic bobbin rim. A greater distance of varnish wire from bobbin would enable easier, safer, less critical from edge, and therefore faster to dip No melted bobbins This can help keep cost down.
guest01 (威望:1) (广东 东莞) 其它行业 经理 - 不管是否站在Q的职位上,我永远不会离开质量的工作...
句子组合好象本身就有问题,还有那些关于实物及方位的,没看到东西也不明白..........
