关于p值大小在minitab
minitab的P值一般为0.05标准
但好像还有几个地方标准定的是 0.1
谁能指出来????
欧立威 (威望:52) (福建 厦门) 咨询业 咨询顾问
是吗?你们老师没告诉你们吗?:lol::lol::lol:
Anderson-Darling tests P必须大于10%
Ryan-Joiner test P必须大于10%
Kolmogorov-Smirnov test P必须大于15%
我摘了一段MINTAB关于Normal Test的Mini的说明,奇怪的是恰好有这些内容,可能是MINTAB公司只在我的软件上写了这些?请参考:
Test results
The normality tests evaluate the null hypothesis (H0) that the data are normally distributed. If the p-value for the test is less than your chosen a-level, then you must reject H0 and conclude that your data are not normally distributed.
The p-value for the Anderson-Darling normality test (bottom right) of the cooking oil data is 0.970. This value is greater than the chosen a-level of 0.10, thus the dietician will not reject H0. There is not enough evidence to suggest that the data are not normally distributed.
The Ryan-Joiner and Kolmogorov-Smirnov tests (not shown) produce similar results. The Ryan-Joiner test produces an approximate p-value of > 0.10, and the Kolmogorov-Smirnov test produces an approximate p-value of > 0.15.
?All Rights Reserved. 2000 Minitab, Inc.
27 个回复,游客无法查看回复,更多功能请登录注册
龙天
龙天
我努力,我进步,我付出,我收获,我坚持,我成功!
