[上海] 欧洲汽车零部件公司 招聘 质量工程师
目前招聘QMS PQ CQ 项目质量等多个方向,职位真实,非诚勿扰,微信电话同号
1. 负责量产产品质量方面的工作,组织AMC进行问题解决活动,开展持续改进活动;
In charge of mass production quality job, organize AMC team to solve the problem and do continuous improvement;
2. 负责不合格品的日常分析和处理,协调可疑品的控制(包括GP12);
In charge of non-conformity daily analysis and disposition, also coordinate to hold of all suspect products (GP12);
3. 主导问题解决跨功能小组运用8D过程:
Lead Problem Resolution Cross Functional Team using 8D-process:
a) 为了解决问题和验证顾客或公司关注项,分析任何产品的不符合;
To analyze any product non-conformities in order to solve issues and verify customer or company concern.
b) 根据需要,和CQS沟通和跟踪8D;
To communicate and follow up (8D) with CQS according to need.
c) 分析内部PPM,发起持续改进的行动(如PDCA,标准化,防错,产品变更,RPN降低);
To analyze internal ppm, and generate continuous improvement actions (e.g. PDCA, standards, poka-yoke, product changes, RPN reduction);
4. 检查是否其它工厂有影响,运用AS53(Q Alert);
Check if other plants are affected and apply AS 53 (Q Alert) ;
5. 控制计划的更新,确保质量计划文件总是更新(如PFMEA, SWI, visual aids…);
Update control plans and ensure that quality planning documentation is always updated (e.g. PFMEA, SWI, visual aids);
6. 确认OPI 4的行动计划正确有效;
Verify OPI 4 actions is correct and effective;
7. 参与产品/过程/Dock审核(包括AS67);
Participate in product/process/dock audits (inc AS 67);
8. 通过积极的参与,支持LESSON LEARNED的实施和维护;
Support implementation and maintenance of lessons learned system by active involvement;
9. 负责完成上级交办的其他事务;
Fulfill other business required by Superior;
9. 负责完成上级交办的其他事务;
0 个回复
