常用英語--SMT
序號 漢語意義 英文翻譯
焊錫品質類
1 冷焊 cold solder
2 零件偏移 component shifted
3 污損 contamination
4 壞件 damaged component
5 錫多 excessive solder
6 裝插不良 improper insertion
7 絕緣不良 insulation damaged
8 線腳長 lead protrusion out of spec
9 漏點膠 missing glue
10 漏標示 missing marking
11 近似短路 near short
12 無線尾 no lead protruded
13 翹皮 peeling off
14 極性反 polarity reversed
15 成型不良 poor preforming
16 錫橋 solder bridge
17 錫裂 solder crack
18 錫尖 solder icicle
19 錫少 solder insufficient
20 防焊漆膠落 solder mask peeling off
21 錫渣 solder spatter
22 錫洞 solder void
23 錯件 wrong part
ICT Fail Cause and Repair Actions
1 短路 Short
2 零件插反 Backward Part
3 板丟失 Board Lost
4 板修復 Board Repaired
5 板報廢 Board Scrapped
6 板送去分析 Board Sent For Analysis
7 零件損壞 Broken Part
8 零件缺陷 Defective Part
9 掉件 Missing part
10 加零件 Part Added
11 零件修復 Part Repaired
12 換零件 Part Replaced
13 PCB缺陷 PCB Defect
14 PCB開路 PCB Open
15 加錫 Solder Added
16 橋焊 Solder Bridge
17 去錫 Solder Removed
Solding quality
1 空焊 Empty Solder
2 包焊 Excess Solder
3 浮焊 Floating Solder
4 冰柱 Icing
5 虛焊 Inveracious Soldering
6 掉件,漏件 Missing Component
7 開路 Open
8 漏焊 Open Solder
9 錫橋 Solder Bridge
10 錫尖突出 Solder Tip
11 錫裂 Split Solder
Operational defect terms
1 零件插反 Backward Part
2 零件損壞 Broken Part
3 碰傷 Bumps
4 異物 Foreign Part
5 零件錯位 Misaligned Part
6 漏件 Missing Parts (component)
7 粘膠 Paint Adhesion
8 刮傷 Scratches
9 錯件 Wrong Part
Others
1 不正常 Abnormal
2 附件 Accessory
3 外觀 Apperance
4 裝配 Assembling
5 附著,貼附 Attached
6 彎曲 Bent
7 束線 Bind
8 翹皮 Blister/peeling
9 接 Bridge
10 破損 Broken
11 毛邊 Burrs
12 裂紋 Chip / crack
13 夾住 Clip
14 污染 Contamination
15 腐蝕 Corrosion
16 交叉 Cross
17 損壞 Damage
18 減少 Decrease
19 深刮傷 Deep Scratch
20 缺點 Defect
21 變形 Deformed
22 凹痕 Dent
23 偏差 Deviation
24 尺寸 Dimension
25 變色(白化) Discoloration
26 化狀箱 Display box
27 雙重 Double
28 脫落 Drop , Tall off
29 超過 Excess
30 假焊 False Solder (Cold)
31 頻率 Fequency
32 塞住 Fill Up
33 浮 Float
34 異物 Foreign Material
35 碎片塞 Fragement
36 膠 Glue
37 溢膠 Glue overflow
38 重 Heavy
39 不清楚 illegible
40 不完全 Incomplete
41 增加 Increase
42 確認 Indentify
43 指示燈 Indicate Lamp
44 不合治具 Ingagued
45 未固定 Insecurely
46 插配 Insertion
47 內部 Inside
48 幹擾 Interference
49 間斷,不安定 Intermittent
50 雜物 Junk
51 糾纏 Kink
52 布置,配置 Layout
53 線腳 Lead
54 淺音 Leakage Sound
55 翹起 Lifted
56 輕 Light
57 位置 Location
58 鬆 Loose
59 方向不對 Misorientation
60 未鍍表層 Misplating
61 欠缺 Missing
62 混 Mix
63 多重 Multiple
64 不良 No Good (NG)
65 偏心 Off center
66 振盪 Oscillation
67 外部 Outside
68 脫漆 Paint drop
69 部分 Partial
70 銅箔 Pattem (PAD)
71 太差 Poor
72 凸 Protrude
73 殘留物 Residue
74 粗糙 Roughness
75 生鏽 Rust
76 LED 數字分節 Segment
77 陷 Sink
78 滑動 Slide
79 脫落 Slip
80 錫珠 Solder Ball
81 流錫 Solder Flow
82 分開,分隔 Sparation
83 污點 Stain
84 粘 Stick
85 薄 Thickness
86 緊 Tight
87 透明 Transparent
88 不平 Uneven
89 不順 Unsmooth
90 上下顛倒 Upside down
91 漆 Varnish Paint
92 缺洞 Void (Holes)
93 弱 Weak
焊錫品質類
1 冷焊 cold solder
3 污損 contamination
9 漏點膠 missing glue
11 近似短路 near short
13 翹皮 peeling off
16 錫橋 solder bridge
17 錫裂 solder crack
18 錫尖 solder icicle
22 錫洞 solder void
23 錯件 wrong part
1 短路 Short
3 板丟失 Board Lost
7 零件損壞 Broken Part
9 掉件 Missing part
10 加零件 Part Added
13 PCB缺陷 PCB Defect
14 PCB開路 PCB Open
15 加錫 Solder Added
16 橋焊 Solder Bridge
Solding quality
1 空焊 Empty Solder
2 包焊 Excess Solder
4 冰柱 Icing
7 開路 Open
8 漏焊 Open Solder
9 錫橋 Solder Bridge
10 錫尖突出 Solder Tip
11 錫裂 Split Solder
2 零件損壞 Broken Part
3 碰傷 Bumps
4 異物 Foreign Part
7 粘膠 Paint Adhesion
8 刮傷 Scratches
9 錯件 Wrong Part
Others
1 不正常 Abnormal
2 附件 Accessory
3 外觀 Apperance
4 裝配 Assembling
5 附著,貼附 Attached
6 彎曲 Bent
7 束線 Bind
9 接 Bridge
10 破損 Broken
11 毛邊 Burrs
12 裂紋 Chip / crack
13 夾住 Clip
14 污染 Contamination
15 腐蝕 Corrosion
16 交叉 Cross
17 損壞 Damage
18 減少 Decrease
19 深刮傷 Deep Scratch
20 缺點 Defect
21 變形 Deformed
22 凹痕 Dent
23 偏差 Deviation
24 尺寸 Dimension
26 化狀箱 Display box
27 雙重 Double
29 超過 Excess
31 頻率 Fequency
32 塞住 Fill Up
33 浮 Float
35 碎片塞 Fragement
36 膠 Glue
37 溢膠 Glue overflow
38 重 Heavy
39 不清楚 illegible
40 不完全 Incomplete
41 增加 Increase
42 確認 Indentify
44 不合治具 Ingagued
45 未固定 Insecurely
46 插配 Insertion
47 內部 Inside
48 幹擾 Interference
50 雜物 Junk
51 糾纏 Kink
52 布置,配置 Layout
53 線腳 Lead
54 淺音 Leakage Sound
55 翹起 Lifted
56 輕 Light
57 位置 Location
58 鬆 Loose
60 未鍍表層 Misplating
61 欠缺 Missing
62 混 Mix
63 多重 Multiple
64 不良 No Good (NG)
65 偏心 Off center
66 振盪 Oscillation
67 外部 Outside
68 脫漆 Paint drop
69 部分 Partial
70 銅箔 Pattem (PAD)
71 太差 Poor
72 凸 Protrude
73 殘留物 Residue
74 粗糙 Roughness
75 生鏽 Rust
76 LED 數字分節 Segment
77 陷 Sink
78 滑動 Slide
79 脫落 Slip
80 錫珠 Solder Ball
81 流錫 Solder Flow
82 分開,分隔 Sparation
83 污點 Stain
84 粘 Stick
85 薄 Thickness
86 緊 Tight
87 透明 Transparent
88 不平 Uneven
89 不順 Unsmooth
90 上下顛倒 Upside down
91 漆 Varnish Paint
92 缺洞 Void (Holes)
93 弱 Weak
8 个回复
linken_1840 (威望:2) (广东 佛山)
