电池技术手册5
Coating process
 Process equipment
 Quality control
 Key control points
Coating and slurry delivery system
Film quality control
 Uniformity (Thickness, weight/area)
 Film impedance
 Pull strength
 Appearance
 Film dryness
Factors to film uniformity
 Stability of slurry delivery speed.
 Stability of Mylar speed.
 Slurry pressure inside slot die
 Slot die size: width, thickness, gap, chamber.
 Slurry particle size distribution.
 Slurry property: Viscosity, density, stability, etc.
 Others
How can we obtain desired film
 Well-mixed slurry with desired particle size distribution.
 Digital motor for precision gear pump.
 Precision service motor for Mylar rolling.
 Stirring the slurry to guarantee its stability.
Real time monitor the pressure inside the slot die.
 Real time monitor film thickness
An example of uniformity control
Conclusion
 Special mixing workheads and procedures to obtain desired mixing slurry with ideal particle size distribution, which is very important for the coating quality and product performance.
 Systematic process control to obtain a perfect film quality, especially the uniformity.
第三章 包装基本知识
Content
Material status
- Foil melting temp(DSC)
- Sealant melting temp(DSC)
- Suitable sealing temp range
Top sealing conflict
- Different temp curve: foil-sealant and foil-foil
  • Rubber: Poor heat conductive
Solution and evaluation result
- Bare battery heating or tab heating
- Evaluation result
I. Material status
Foil & sealant DSC
II. Top sealing conflict
  1. Different temp curve at different area
- Foil-foil is easy to be melt and sealed
  • Foil-sealant need more heat to be melt
  1. Root cause
- Bare battery will absorb amount of heat
- Poor heat conductive of rubber
  1. Peel strength compare
- Foil-foil can be sealed from 180deg/0.4Mpa/2s
- Foil-sealant(rubber side) has no strength even 190deg/0.4Mpa/4s
III. Solution
  1. Resolve method
0 个回复,游客无法查看回复,更多功能请登录注册
