VBA---通過Z值算PPM
以下VBA宏放在Excel, word中都可以運行,各一個參數Z值就可以算出對應的PPM
Private Function SToPPM(Z As Double) As Double
Dim GPI As Double
Dim DX As Double
Dim temp As Double
Dim Count As Long
Dim Y1 As Double, Y2 As Double
DX = 0.01
GPI = 1 / Sqr(2 3.1415926) 1000000
Y2 = GPI Exp(-0.5 Z* Z)
Count = 0
SToPPM = 0
Do While Y2 > 0.00001
Y1 = Y2
Count = Count + 1
If Z> 0 Then
Y2 = GPI Exp(-0.5 (Z+ DX Count) (Z+ DX * Count))
Else
Y2 = GPI Exp(-0.5 (Z- DX Count) (Z- DX * Count))
End If
SToPPM = SToPPM + ((Y1 + Y2) * DX) / 2
Loop
SToPPM = SToPPM
End Function
clarkbao (威望:0) - 品質工程師
新建一个Excel档案,在菜单栏选择宏-->宏,会打开一个对话框,随便给一个名字,选择。
清空所有代码,再把上面的代码复制进去就可以了
6 个回复,游客无法查看回复,更多功能请登录注册
clarkbao
clarkbao
品質工程師
