【讨论一下】这两个不符合项怎么关闭,望高手指点一二
1、NC description:Some control plan does not include error-proofing method.部分控制计划未包括防措技术。
Requirement:Annex of ISO16949:2002. Objective evidence:The control plan #99012320103did not include error-proofing methods.Requirement:7.3.3.2of ISO 16949:2002
2、NC description:Some part of the Process FMEA was not correctly conducted.部分过程FMEA 未正确进行。
Objective evidence:With regard to some part of the Process FMEA#99012320103,potential failuress were analyzed assuming process is not in normal condition, for instance,improper operation bly operator and incorrect mixing of material.有关过程FMEA99012320103,其潜在失效的分析是基于不正常的过程,如员工操作不当,配料不正确。
惠惠80 (威望:11) (辽宁 大连) 汽车制造相关 经理 - 外企QM经理及MBB,群主(61625923)为...
可以再详细一些吗?最好能举例说明!
让大家了解被判定为不符合的过程才能帮你哦!
7 个回复,游客无法查看回复,更多功能请登录注册
