又有新的ROHS豁免项啦
RoHS指令豁免项目
Exempted Items of RoHS Directive
截止2006年4月21日前,欧盟委员会决议正式公布的RoHS指令之豁免项
Exempted items published in EU Commission official journal
1 Mercury in compact fluorescent lamps not exceeding 5 mg per lamp.
1 小型荧光灯中的汞,汞含量不超过5mg/灯。
2 Mercury in straight fluorescent lamps for general purposes not exceeding:
2 普通用途直荧光灯中的汞,汞含量不超过:
• Triphosphate with normal lifetime 5 mg;
• Triphosphate with long lifetime 8 mg.
3 Mercury in straight fluorescent lamps for special purposes.
4 Mercury in other lamps not specifically mentioned in this Annex.
4.本附录未明确提出的其他灯具中的汞
5 Lead in glass of cathode ray tubes, electronic components and fluorescent tubes.
5.阴极射线管,电子元件以及荧光管的玻璃中的铅
6 Lead as an alloying element in:
• Steel containing up to 0.35 % lead by weight;
钢里,铅的重量含量不超过0.35 %
• Aluminium containing up to 0.4 % lead by weight;
铝里,铅的重量含量不超过0.4%
• Copper alloy containing up to 4 % lead by weight.
铜合金里,铅的重量含量不超过4%
7 • Lead in high melting temperature type solders (i.e. lead-based alloys containing 85 % by
equipment for switching, signalling, transmission as well as network management for
用于服务器,存储器和存储系统中的铅,用于交换,信号和传输,以及电信网络管理的网络
基础设施设备中焊料中的铅。
• Lead in electronic ceramic parts (e.g. piezoelectronic devices).
电子陶瓷产品中的铅(如:高压电子装置)
8 Cadmium and its compounds in electrical contacts and cadmium plating except for applications
banned under Directive 91/338/EEC amending Directive 76/769/EEC relating to restrictions on the
marketing and use of certain dangerous substances and preparations.
根据修改关于限制特定危险物质和与制品销售和使用的第76/796/EEC号指令的91/338/EEC
号指令禁止以外的镉电镀。
9 Hexavalent chromium as an anti-corrosion of the carbon steel cooling system in absorption
refrigerators.
在吸收是电冰箱中作为碳钢冷却系统防腐剂的六价铬。
9a DecaBDE in polymeric applications.
9a 应用于聚合体中的DecaBDE(十溴二本醚)
9b Lead in lead-bronze bearing shells and bushes.
9b 用于铅铜合金轴承和衬套中的铅。
11 Lead used in compliant pin connector systems.
11 适应钉联结器系统中的铅。
12 Lead as a coating material for the thermal conduction module c-ring.
12 用于热传导模块C-环的被覆材料中的铅。
13 Lead and cadmium in optical and filter glass.
13 用于光学及滤波器玻璃中的铅和镉。
14 Lead in solders consisting of more than two elements for the connection between the pins and the
package of microprocessors with a lead content of more than 80% and less than 85% by weight.
14 用于连接插脚的含有两种以上元素的焊料中的铅,以及微处理器包中含量在80%--85%之间
的铅。
15 Lead in solders to complete a viable electrical connection between semiconductor die and carrier
within integrated circuit Flip Chip packages.
15.用于在集成电路Flip Chip包之内连接半导体模块和载波器的焊料中的铅。
2006年4月21日,欧盟委员会增加了RoHS指令的豁免项目,由原来的15条增加到20条。新增项目
主要针对铅元素,内容如下:
17.用在专业复印领域高强度放电灯辐射介质中的铅的卤化物。
well as when used as speciality lamps for
diazo-printing reprography, lithography, insect traps, photochemical and curing
processes containing phosphors such as SMS ((Sr,Ba)2MgSi2O7:Pb).
18.放电管的荧光粉中作为催化剂的铅(铅的重量小于等于1%)可以豁免,当放电管用于含有
磷元素(如BSP (BaSi2O5:Pb))的日晒灯时,以及用于重氮印刷、平板印刷、捕虫、光化学、
固化工艺等等专业领域的灯具时。
19.小型节能灯中作为主要汞合金的特定的PbBiSn-Hg 和PbInSn-Hg中的铅,以及作为辅助汞合
金的PbSn-Hg中的铅。
20. LCD 的平板荧光灯前后基板键合时所用玻璃中的铅。
详情请看:http://europa.eu.int/comm/envi ... n.pdf
4.本附录未明确提出的其他灯具中的汞
钢里,铅的重量含量不超过0.35 %
铝里,铅的重量含量不超过0.4%
铜合金里,铅的重量含量不超过4%
- 用于高温融化焊料中的铅(即:锡铅焊料合金中铅含量超过85%)
基础设施设备中焊料中的铅。
电子陶瓷产品中的铅(如:高压电子装置)
号指令禁止以外的镉电镀。
refrigerators.
9b 用于铅铜合金轴承和衬套中的铅。
11 适应钉联结器系统中的铅。
13 用于光学及滤波器玻璃中的铅和镉。
的铅。
主要针对铅元素,内容如下:
- Lead in linear incandescent lamps with silicate coated tubes.
- Lead halide as radiant agent in High Intensity Discharge (HID) lamps used for
- Lead as activator in the fluorescent powder (1 % lead by weight or less) of discharge
固化工艺等等专业领域的灯具时。
- Lead with PbBiSn-Hg and PbInSn-Hg in specific compositions as main amalgam and with
金的PbSn-Hg中的铅。
- Lead oxide in glass used for bonding front and rear substrates of flat fluorescent
19 个回复
chensijiang (威望:2) (北京 ) 教育培训 工程师 - 环境及职业健康安全管理体系 风险管理
