喷漆硬度测试
DUR-O-test(type:BYK-Gardner), samples
DUR-O-Test儀(型號:BYK-Gardner),待測部件。
6.1 Set up spring/安裝彈簧
a. Turn and open the awl and inside pin of equipment
轉動并打開錐尖及其內針;
b. Insert the spri
插入彈簧;
c. Reset the awl and inside pin
將錐尖及其內針复位。
6.2 Adjust force to customer's requirement(100gf,200gf etc.) then stand and stable the
equipment.
根据客户要求調節彈力(100克,200克等),立起并固定儀器;
6.3 Hardness testing 硬度測量:
a. Put the tester head on the plastic parts vertically
將測試儀測頭垂直置于待測組件上;
b. Keep pressure on tester and pull it move around 10mm. Tester head surface have to
keep close with plastic part surface
給待測件表面加壓,并平行于表面拉動待測組件約10mm;
c. Check the plastic parts surface, if the hardness not enough then the surface will
have scratch mark
檢查組件外觀,如果涂層硬度不夠表面將留下一條划痕;
d. If no scratch then OK, otherwise not OK and mark "x".
如果符合要求,在報告上划“ v ”;否則,划“X”;
e. Retest if needed, procedure same as ab
如果必要的話,重复上述測試;
f. Loose screw and spring, put frame on "0" position, spring can been kept inside of
equipment
打開螺釘放松彈簧,并舉起支架至“O”位置,彈簧可不取出;
Attention: After tested have to unload the spring.
注意:測試完后須給彈簧卸載。
- Test procedure測試程序:
轉動并打開錐尖及其內針;
b. Insert the spri
插入彈簧;
將錐尖及其內針复位。
equipment.
將測試儀測頭垂直置于待測組件上;
have scratch mark
如果必要的話,重复上述測試;
equipment
注意:測試完后須給彈簧卸載。
fxwu (威望:0) (江苏 ) 电子制造 主管
