PCB走線寬度與通過電流的關系
請教各位大俠:
誰能提供PCB走線與電流關系的計算公式。或者相關標準。最好是IPC標準。急需!
謝謝!
EMIAL:xiaoenq#sina.com
xiaozengxi (威望:0) (广东 广州)
This Javascript web calculator calculates the trace width for printed circuit boards based on a curve fit to IPC-2221 (formerly IPC-D-275). Also see the via calculator.
New features:
Results update as you type
Several choices of units
Units and other settings are saved between sessions
Blog format allows user comments
Notes:
The trace width is calculated as follows:
First, the Area is calculated:
Area = (Current/(k*(Temp_Rise)^b))^(1/c)
Then, the Width is calculated:
Width = Area/(Thickness*1.378)
For IPC-2221 internal layers: k = 0.0150, b = 0.5453, c = 0.7349
For IPC-2221 external layers: k = 0.0647, b = 0.4281, c = 0.6732
where k, b, and c are constants resulting from curve fitting to the IPC-2221 curves
For frequently asked questions, see the comments.
3 个回复,游客无法查看回复,更多功能请登录注册
