Shainin DOE software Qualitron DoES™ 3.0 for Windows
有没有谁用过Qualitron DoES™ 3.0 for Windows?
DoES is the only software on the market that captures the intuitive RED X Methodology for quality improvement, as described by Keki Bhote in his book World Class Quality. Based on the latest variation research and designed experiments techniques, DoES simplifies and automates the intensive math and interpretation process associated with DOE.
DoES mathematically reduces the data using statistically accepted formulae, helps interpret the data, provides valuable visual displays in the form of charts and graphs, maintains experimental data files, and prints both high resolution graphics and text. It is a powerful tool to guide the user through the step by step methodology of designed experiments.
Combined with data obtained from SPC, DoES provides the necessary methodology to analyze and eliminate out of control processes. What SPC was to the 80's, DOE is to the 90's and beyond. DoES will be there to help. When it comes to reducing variability, improving product designs and refining manufacturing processes, DoES will be at the center of your quality revolution.
liwei7225 (威望:0)
i desire for the latest software. i read the book--world class quality.
if you have, would you pls send it to me?
my email:liwei1976212#163.com
thanks a lot
