仪器中英对照
1 Absolute coolatnt proof caliper 防水防油数显卡尺
2 Absolute Digimatic caliper 数显卡尺
3 Absolute solar caliper 太阳能数显卡尺
4 Vernier caliper 游标卡尺
5 diamond Master vernier caliper 钻石形游标卡尺
6 dial caliper 带表卡尺
7 digimatic caliper 数显尖型夹钳卡尺
8 vernier caliper 带有拇指锁紧装置游标卡尺
9 digimatic carbon fiber caliper 数显碳纤卡尺
10 long jaw vernier caliper 长爪游标卡尺
11 digimatic caliper 带有尖型和标准型量爪数显卡尺
12 Vernier caliper 带有尖型和标准型量爪游标卡尺
13 offset caliper/offset centerline caliper 偏置卡尺/偏置中心线卡尺
14 point caliper 尖爪卡尺
15 blade type caliper 薄片游标卡尺
16 neck caliper/outside point caliper 颈套型游标卡尺/外点式游标卡尺
17 tube thickness caliper/swivel vernier caliper 管壁厚度卡尺
18 scribing caliper/digimatic snap caliper 划线卡尺/数显快速卡尺
19 back-jaw centerline caliper 背量爪式中心线卡尺
20 inside caliper 内径卡尺
21 absolute low force caliper 低测力卡尺
22 hook type vernier caliper 卡钳式游标卡尺
23 absolute digimatic depth gages 数显深度尺
24 vernier depth gages/dial depth gages (带表)游标深度尺
25 extension bases/depth base attachment 加宽基面/深度基面附件
千分尺类:
1 Digimatic Micrometer 数显千分尺
2 quickmike Quickmike快速测量千分尺
3 outside micrometer 外径千分尺
4 quick-setting outside micrometers 快速设定型外径千分尺
5 spine micrometers 齿槽(花键)千分尺
6 point micrometers 尖头千分尺
7 Crimp Height Micrometers 夹钳式高度千分尺
8 v-anvil micrometers V砧(三勾、五勾)千分尺
9 tube micrometers 管壁千分尺
10 universal micrometers 万能千分尺
11 uni-mike “Uni-Mike”千分尺
12 sheet metal micrometers U型千分尺
13 balde micrometers 薄片千分尺
14 disk micrometers 盘式(公法线)千分尺
15 screw thread micrometers 螺纹千分尺
16 gear tooth micrometers 齿轮外径千分尺
17 can seam micrometers 罐型接缝千分尺
18 hub micrometers 轮毂千分尺
19 digit outside micrometers 数字外径千分尺
20 caliper type micrometers 卡尺型千分尺
21 digimatic micrometers 可调测力型数显千分尺
22 low force micrometers/digimatic bench micrometer 低测力千分尺/数显台式千分尺
23 snap meters/dial snap meters 带表千分尺(杠杆卡规)
24 indicating micrometers/outside micrometers 带表千分尺
25 limit micrometers 极限千分尺
26 optical flats/optical parallels 平行平晶/平面平晶
27 micrometer standards/standards for screw thread micrometers (普通、螺纹、V型测砧)千分尺校正杆
28 micrometer stands 千分尺尺座
29 groove micrometers 凹槽千分尺
30 depth micrometers 深度千分尺
31 borematic 孔径千分尺
32 digimatic holtest 数显三点内径千分尺
33 holtest 三点内径千分尺
34 inside micrometers 内径千分尺
35 digimatic tubular inside micrometers 数显接杆式内径千分尺
36 tubular inside micrometers 接杆式内径千分尺
37 micrometer heads 微分头
表类:
1 IDF series digimatic indicators IDF系列数显千分表/百分表
2 IDC series digimatic indicators IDC系列数显千分表/百分表
3 IDS series digimatic indicators IDS系列数显千分表/百分表
4 IDU series digimatic indicators IDU系列数显千分表/百分表
5 LGS series digimatic indicators LGS系列数显千分表/百分表
6 LGD,LGD-M Linear gages 光栅长度计
7 Dial indicators 1系列 1系列百分表/千分表
8 Dial indicators 2系列 2系列百分表/千分表
9 Dial indicators 3系列 3系列百分表/千分表
10 Dial indicators 4系列 4系列百分表/千分表
11 contact points 测头
12 magnetic stands 磁性支架/测量台
13 bore gages 内径表
14 dial bore gages (粗糙表面)内径表
15 setting rings 环规
16 dial depth gages 深度表
17 thickness gages 厚度表
18 caliper gages 测径器
19 dial test indicators 杠杆百分表/千分表
20 accessories for dial test indicators 杠杆百分表/千分表附件
21 pocket type dial test indicators 袖珍型杠杆百分表/千分表
22 accessories for pocket type dial test indicators 袖珍型杠杆百分表/千分表附件
高度尺类:
1 Linear Height 2D测量仪
2 QM-Hite 高精度数显高度尺
3 heightmatic 高精度高度尺
4 digimatic heitht gages 数显高度尺
5 digital counter type dial heitht gages 带表带计数器型高度尺
6 dial height gages 带表高度尺
7 vernier height gages 游标高度尺
8 scribers for height gages/accessories for height gages 高度尺划线头及高度尺附件
投影仪:
1 profile projectors series302 测量投影机PJ-A3000系列
2 profile projectors series303 测量投影机PJ-H3000系列
3 profile projectors series303 测量投影机PJ-500系列
4 profile projectors series172 测量投影机PH-3515F -应用于刀具(立铣刀、片铣刀、片切锯)的观察,圆柱形(螺纹、弹簧)
5 profile projectors series304 测量投影机PV-5100系列 -最适合于在投影屏上与放大图纸对较测量,投影像的描图,手表、电子、贵金属部件等测量
显微镜:
1 QUICK IMAGE 二次元影像测定机QUICK IMAGE系列-应用于有段差的机械零件及电子零件
2 Microscopes MF-UA 测量显微镜MF-UA系列
3 Microscopes unit for semiconductor inspection FS-70高倍率观察显微镜
4 Vision Unit--Vision System Retrofit for Microscopes 显微镜加强系统-影像装置
粗糙度仪:
1 portable surface roughness tester surftest SJ-201 便携式表面粗糙度测量仪SJ-201
2 portable surface roughness tester surftest SJ-301 便携式表面粗糙度测量仪SJ-301
3 portable surface roughness tester surftest SJ-400 便携式表面粗糙度测量仪SJ-400
4 Surface Roughness Testers Surftest SV-2000/3000 表面粗糙度测量仪SV-2000/3000系列
tome3666 (威望:4) (山东 青岛) 汽车制造相关 咨询顾问 - 汽车体系认证
非常感谢楼主将这么适用的好资料与大家分享!支持您!
15 个回复,游客无法查看回复,更多功能请登录注册
