审核不符合项
TS审核结束了,其中有一个不符合项如下:
1、The system of supplier control is not effective:
when auditing the purchasing process,the auditor found that some of the material suppliers
were not at least ISO9001 certified nor planned to obtain ISO9001
Also,some material were purchased from suppliers on a "temporary supplier list"that is not
controlled as per the company's purchasing control procedure.
2、The layout inspection system is not effective:
At QA department ,the coating hardness was not included in the inspection items and
conducted for the layout and functional inspection.(e.g.P/N 107638)
上面的不符合项我们应该怎样整改呀?
上面的不符合项我们应该怎样整改呀?
7 个回复
樱奈儿 (威望:0) (江苏 苏州) 汽车制造相关 员工
供应商质量系统开发计划,供应商审核/PPAP确认,ASL要求.
没有确认的供应商提交PPAP.
要求供应商提交质量系统开发计划
2.检查所有检测标准(WI),确认必要的项目被要求检测.
有的项目不必在每次检测都实施,频率(间隔)可以不同,如,每次生产/出货,或每年一次.
赞同楼上的,不难整改.
